For further definitions, go to Absolute (dynamic) and kinematic viscosity .
Tabulated values of propane viscosity and viscosity units conversion are given below the figures .
Online Propane Viscosity Calculator
The calculator below can be used to calculate propane dynamic or kinematic viscosity at given temperatures and atmospheric pressure.
The output dynamic viscosity is given as Pa*s, N*s/m 2 , cP, mPa*s, lb f *s/ft 2 and lb m /(ft*h),
while the kinematic viscosity is given as cSt, m 2 /s, and ft 2 /s
See also other properties of Propane at varying temperature and pressure : Density and specific weight , Prandtl number , Specific heat (heat capacity) , Thermal conductivity and Thermal diffusivity , and Thermophysical properties at standard conditions ,
as well as dynamic and kinematic viscosity of air , ammonia , benzene , butane , carbon dioxide , ethane , ethanol , ethylene , methane , methanol , nitrogen , oxygen and water .
Dynamic and kinematic viscosity of gaseous propane at atmospheric pressure and varying temperature:
Dynamic and kinematic viscosity of liquid propane at atmospheric pressure and varying temperature:
Dynamic viscosity of propane at varying temperature and 1, 10 and 100 bara (14.5, 145 and 1450 psia):
Kinematic viscosity of propane at varying temperature and 1, 10 and 100 bara (14.5, 145 and 1450 psia):
Dynamic viscosity of propane  at gas-liquid equilibrium pressure:
Kinematic viscosity of propane  at gas-liquid equilibrium pressure:
Dynamic (absolute) and kinematic viscosity of propane at given temperatures and pressures, SI and Imperial units:
State Temperature Pressure Dynamic (Absolute) Viscosity Kinematic Viscosity
[K] [°C] [°F] [bara] [psia] [μPa s] [cP] [lb f s/ft 2 *10 -6 ] [lb m /ft s*10 -6 ] [cSt],
[m 2 /s*10 -6 ]
[ft 2 /s*10 -6 ]
Liquid at
equilibrium
85.53 -187.68 -305.82 1.7E-09 2.5E-08 10780 10.78 225.1 7244 14.70 158.3
100 -173 -280 2.5E-07 3.7E-06 3780.3 3.780 78.95 2540 5.264 56.66
130 -143 -226 0.000176 0.00255 1080.5 1.081 22.57 726.1 1.571 16.91
160 -113 -172 0.00850 0.1233 534.6 0.5346 11.17 359.2 0.8135 8.757
190 -83.2 -118 0.1055 1.530 329.9 0.3299 6.891 221.7 0.5270 5.673
220 -53.2 -63.7 0.6058 8.787 224.3 0.2243 4.684 150.7 0.3779 4.068
250 -23.2 -9.7 2.180 31.62 160.1 0.1601 3.344 107.6 0.2867 3.086
280 6.9 44.3 5.817 84.37 117.1 0.1171 2.446 78.69 0.2256 2.428
310 36.9 98.3 12.73 184.6 85.74 0.08574 1.791 57.61 0.1813 1.951
320 46.9 116 15.99 231.9 76.78 0.07678 1.604 51.59 0.1688 1.817
340 66.9 152 24.32 352.7 60.01 0.06001 1.253 40.33 0.1457 1.568
355 81.9 179 32.43 470.4 47.14 0.04714 0.9845 31.67 0.1285 1.384
360 86.9 188 35.55 515.6 42.27 0.04227 0.8828 28.40 0.1223 1.317
85.53 -187.68 -305.82 1.7E-09 2.5E-08 2.641 0.002641 0.05516 1.775 240090909 2584314536
Gas at
equilibrium
100 -173 -280 2.5E-07 3.7E-06 2.979 0.002979 0.06222 2.002 2217783 23871991
130 -143 -226 0.000176 0.00255 3.717 0.003717 0.07762 2.498 5176 55717
160 -113 -172 0.00850 0.1233 4.483 0.004483 0.09363 3.013 159.0 1712
190 -83.2 -118 0.1055 1.530 5.258 0.005258 0.1098 3.533 17.74 190.9
220 -53.2 -63.7 0.6058 8.787 6.026 0.006026 0.1259 4.049 4.023 43.30
250 -23.2 -9.7 2.180 31.62 6.803 0.006803 0.1421 4.571 1.378 14.83
280 6.9 44.3 5.817 84.37 7.655 0.007655 0.1599 5.144 0.6092 6.557
310 36.9 98.3 12.73 184.6 8.794 0.008794 0.1837 5.909 0.3154 3.395
320 46.9 116 15.99 231.9 9.230 0.009230 0.1928 6.202 0.2583 2.780
340 66.9 152 24.32 352.7 10.57 0.01057 0.2208 7.105 0.1795 1.932
355 81.9 179 32.43 470.4 12.37 0.01237 0.2584 8.314 0.1385 1.491
360 86.9 188 35.55 515.6 13.38 0.01338 0.2794 8.991 0.1269 1.366
Liquid 85.53 -187.62 -305.72 1 14.5 10790 10.79 225.4 7251 14.72 158.4
100 -173 -280 1 14.5 3778 3.778 78.91 2539 5.260 56.62
120 -153 -244 1 14.5 1502 1.502 31.37 1009 2.152 23.17
140 -133 -208 1 14.5 822.9 0.8229 17.19 553.0 1.214 13.07
160 -113 -172 1 14.5 535.5 0.5355 11.18 359.8 0.8147 8.769
180 -93.2 -136 1 14.5 382.5 0.3825 7.989 257.0 0.6008 6.466
200 -73.2 -99.7 1 14.5 288.2 0.2882 6.019 193.7 0.4683 5.040
220 -53.2 -63.7 1 14.5 224.3 0.2243 4.685 150.7 0.3779 4.068
230.74 -42.41 -44.34 1 14.5 197.9 0.1979 4.133 133.0 0.3405 3.665
Gas 230.74 -42.41 -44.34 1 14.5 6.301 0.006301 0.1316 4.234 2.642 28.44
240 -33.2 -27.7 1 14.5 6.559 0.006559 0.1370 4.407 2.872 30.91
260 -13.2 8.3 1 14.5 7.110 0.007110 0.1485 4.778 3.399 36.58
280 6.9 44.3 1 14.5 7.656 0.007656 0.1599 5.145 3.963 42.65
300 26.9 80.3 1 14.5 8.196 0.008196 0.1712 5.507 4.563 49.12
320 46.9 116 1 14.5 8.732 0.008732 0.1824 5.868 5.201 55.98
340 66.9 152 1 14.5 9.262 0.009262 0.1934 6.224 5.877 63.26
360 86.9 188 1 14.5 9.787 0.009787 0.2044 6.577 6.586 70.89
400 127 260 1 14.5 10.82 0.01082 0.2260 7.271 8.111 87.31
500 227 440 1 14.5 13.29 0.01329 0.2776 8.930 12.49 134.4
600 327 620 1 14.5 15.59 0.01559 0.3256 10.48 17.61 189.6
700 427 800 1 14.5 17.70 0.01770 0.3697 11.89 23.35 251.3
800 527 980 1 14.5 19.62 0.01962 0.4098 13.18 29.59 318.5
900 627 1160 1 14.5 21.36 0.02136 0.4461 14.35 36.25 390.2
1000 727 1340 1 14.5 22.93 0.02293 0.4789 15.41 43.25 465.5
85.62 -187.53 -305.55 10 145 10840 10.84 226.4 7284 14.78 159.1
Liquid 100 -173 -280 10 145 3816 3.816 79.70 2564 5.311 57.17
120 -153 -244 10 145 1515 1.515 31.64 1018 2.170 23.36
140 -133 -208 10 145 829.3 0.8293 17.32 557.3 1.223 13.16
160 -113 -172 10 145 539.4 0.5394 11.27 362.5 0.8200 8.826
180 -93.2 -136 10 145 385.3 0.3853 8.047 258.9 0.6046 6.508
200 -73.2 -99.7 10 145 290.4 0.2904 6.065 195.1 0.4713 5.073
220 -53.2 -63.7 10 145 226.2 0.2262 4.724 152.0 0.3806 4.096
240 -33.2 -27.7 10 145 180.0 0.1800 3.759 121.0 0.3150 3.390
260 -13.2 8.3 10 145 145.2 0.1452 3.033 97.57 0.2654 2.857
280 6.9 44.3 10 145 117.9 0.1179 2.462 79.23 0.2267 2.440
300.09 26.94 80.49 10 145 95.19 0.09519 1.988 63.96 0.1945 2.094
Gas 300.09 26.94 80.49 10 145 8.344 0.008344 0.1743 5.607 0.3850 4.144
320 46.9 116 10 145 8.877 0.008877 0.1854 5.965 0.4590 4.941
340 66.9 152 10 145 9.414 0.009414 0.1966 6.326 0.5346 5.754
360 86.9 188 10 145 9.948 0.009948 0.2078 6.685 0.6122 6.589
400 127 260 10 145 11.00 0.01100 0.2297 7.392 0.7761 8.354
500 227 440 10 145 13.48 0.01348 0.2815 9.058 1.234 13.28
600 327 620 10 145 15.76 0.01576 0.3292 10.59 1.758 18.92
700 427 800 10 145 17.86 0.01786 0.3730 12.00 2.343 25.22
800 527 980 10 145 19.76 0.01976 0.4127 13.28 2.975 32.03
900 627 1160 10 145 21.49 0.02149 0.4488 14.44 3.649 39.28
1000 727 1340 10 145 23.04 0.02304 0.4812 15.48 4.354 46.86
Liquid 100 -173 -280 50 725 3996 3.996 83.45 2685 5.550 59.74
200 -73.2 -99.7 50 725 300.3 0.3003 6.273 201.8 0.4849 5.219
300 26.9 80.3 50 725 103.1 0.1031 2.153 69.27 0.2057 2.214
Supercritical
phase
400 127 260 50 725 14.95 0.01495 0.3122 10.04 0.1332 1.434
500 227 440 50 725 15.21 0.01521 0.3176 10.22 0.2453 2.640
Liquid 86.45 -187 -304 100 1450 11310 11.31 236.2 7600 15.38 165.6
100 -173 -280 100 1450 4212 4.212 87.97 2830 5.837 62.83
120 -153 -244 100 1450 1649 1.649 34.44 1108 2.350 25.29
140 -133 -208 100 1450 894.7 0.8947 18.69 601.2 1.311 14.12
160 -113 -172 100 1450 579.3 0.5793 12.10 389.3 0.8742 9.409
180 -93.2 -136 100 1450 413.7 0.4137 8.640 278.0 0.6433 6.924
200 -73.2 -99.7 100 1450 312.8 0.3128 6.533 210.2 0.5019 5.403
220 -53.2 -63.7 100 1450 245.3 0.2453 5.123 164.8 0.4069 4.380
240 -33.2 -27.7 100 1450 197.1 0.1971 4.117 132.4 0.3387 3.646
260 -13.2 8.3 100 1450 161.3 0.1613 3.369 108.4 0.2880 3.100
280 6.9 44.3 100 1450 133.7 0.1337 2.792 89.84 0.2489 2.679
300 26.9 80.3 100 1450 111.7 0.1117 2.333 75.06 0.2179 2.345
320 46.9 116 100 1450 93.65 0.09365 1.956 62.93 0.1927 2.074
340 66.9 152 100 1450 78.30 0.07830 1.635 52.62 0.1714 1.845
360 86.9 188 100 1450 64.77 0.06477 1.353 43.52 0.1530 1.647
Supercritical
phase
400 127 260 100 1450 41.09 0.04109 0.8582 27.61 0.1228 1.322
500 227 440 100 1450 19.83 0.01983 0.4141 13.32 0.1384 1.489
600 327 620 100 1450 19.67 0.01967 0.4108 13.22 0.1986 2.138
700 427 800 100 1450 20.88 0.02088 0.4361 14.03 0.2649 2.851
800 527 980 100 1450 22.27 0.02227 0.4651 14.96 0.3351 3.607
900 627 1160 100 1450 23.62 0.02362 0.4933 15.87 0.4080 4.392
1000 727 1340 100 1450 24.89 0.02489 0.5198 16.73 0.4834 5.203
Unit conversion:
Viscosity Dynamic, Absolute
centipoise [cP], gram/(centimeter second) [g/(cm s)] = poise [P],  kilogram/meter second [kg/m s]=newton second/square meter [N s/m 2 ]= pascal second [Pa s], pound/(foot hour) [lb/(ft h)], pound/(foot second) [lb/(ft s)], reyn [reyn]
  • 1 cP = 0.001 Pa s = 0.01 P = = 0.01 g/(cm sec) = 6.72197x10 -4 lb/(ft s) = 2.4191 lb/(ft h)
  • 1 kg/(m s ) = 1 (N s)/m 2 = 1 Pa s = 10 P = 1000 cP = 0.672197 lb/(ft s) = 2419.09 lb/(ft h)
  • 1 (N s)/m 2 = 1 kg/(m s ) = 1 Pa s = 10 P = 1000 cP = 0.672197 lb/(ft s) = 2419.09 lb/(ft h)
  • 1 Pa s = 1 kg/(m s) = 1 (N s)/m 2 = 10 P = 1000 cP = 0.672197 lb/(ft s) = 2419.08 lb/(ft h) =  0.00014504 reyn
  • 1 reyn = 6894.76 Pa s
Viscosity Kinematic
centistoke [cSt] = square millimeter/second [mm 2 /s], square foot/hour [ft 2 /h], square foot/second [ft 2 /s], square inch/second [in 2 /s], square meter/hour [m 2 /h], square meter/second [m 2 /s], stoke [St] = square centimeter/second [cm 2 /s]
  • 1 cm 2 /s = 1 St = 100 mm 2 /s = 100 cSt = 1x10 -4 m 2 /s = 0.36 m 2 /h = 1.07639x10 -3 ft 2 /s = 3.875008 ft 2 /h = 0.1550003 in 2 /s
  • 1 cSt = 1 mm 2 /s = 0.01 St = 1x10 -6 m 2 /s = 0.0036 m 2 /h = 1.07639x10 -5 ft 2 /s = 0.03875008 ft 2 /h = 0.001550003 in 2 /s
  • 1 ft 2 /h = 2.7778x10 -4 ft 2 /s = 0.04 in 2 /s = 2.58064x10 -5 m 2 /s = 0.09290304 m 2 /h = 25.8064 cS = 0.258064 St
  • 1 ft 2 /s = 3600 ft 2 /h = 144 in 2 /s = 0.09290304 m 2 /s = 334.451 m 2 /h = 92903.04 cSt = 929.0304 St
  • 1 in 2 /s = 0.0069444 ft 2 /s = 25 ft 2 /h = 0.00064516 m 2 /s = 2.322576 m 2 /h = 645.16 cSt = 6.4516 St
  • 1 m 2 /h = 1/3600 m 2 /s = 2.7778x10 -4 m 2 /s = 2.7778 cm 2 /s = 277.78 mm 2 /s = 277.78 cSt = 2.7778 St = 0.00298998 ft 2 /s = 10.7639 ft 2 /h = 0.430556 in 2 /s
  • 1 m 2 /s = 3600 m 2 /h = 1x10 4 cm 2 /s = 1x10 4 St = 1x10 6 mm 2 /s = 1x10 6 cSt = 10.7639 ft 2 /s = 38750.08 ft 2 /h = 1550003 in 2 /s
  • 1 mm 2 /s = 1 cSt = 1x10 -6 m 2 /s = 0.0036 m 2 /h = 0.01 cm 2 /s = 0.01 St = 1.07639x10 -5 ft 2 /s = 0.03875008 ft 2 /h = 0.001550003 in 2 /s
  • 1 St = 1 cm 2 /s = 100 cSt = 100 mm 2 /s = 1x10 -4 m 2 /s = 0.36 m 2 /h = 1.076x10 -3 ft 2 /s = 3.875008 ft 2 /h = 0.1550003 in 2 /s
Fluid Mechanics
Material Properties
Thermodynamics
Viscosities
Air - Dynamic and Kinematic Viscosity
Centrifugal Pumps - Viscosity Influence
Hydrodynamic losses through pumps depends on fluid viscosities.
Kinematic Viscosity - Convert between Units
Convert between Centistokes, Saybolt and Redwood seconds.
LPG Pipes - Pressure Loss vs. Gas Flow
Resistance and pressure loss in liquid LPG pipes.
Propane - Latent Heat of Vaporization vs. Temperature
Latent heat with vaporized propane.
Propane - Specific Heat vs. Temperature and Pressure
Online calculators, figures and tables with specific heat, Cp and Cv, of gasous and liquid propane, C3H8 vs. temperature and pressure - Imperial and SI Units .
Propane - Thermal Diffusivity vs. Temperature and Pressure
Propane - Vapor Pressure vs. Temperature
Vapor pressure vs. temperature.
Propane Air Mixture
Energy content and specific gravity of propane air mixtures.
Propane Butane Mixture - Evaporation Pressure
Propane Gas - Sizing of Pipe Lines
Propane Gas Piping - Low Pressure Capacity vs. Size
Sizing of low pressure propane gas pipe lines - Imperial units.
Viscosity - Converting Chart
Viscous Liquids - Max. Delivery Flow Velocities
Recommended max. flow velocities on delivery sides of pumps in viscous systems.
Water - Dynamic (Absolute) and Kinematic Viscosity vs. Temperature and Pressure
