Viscous Liquids - Max. Delivery Flow Velocities
As a rule of thumb - velocities that can be used in design of piping and pumping systems for viscous liquids:
Pipe Dimension | Delivery Velocity | ||
inches | mm | m/s | ft/s |
1 | 25 | 1 | 3.5 |
2 | 50 | 1.1 | 3.6 |
3 | 75 | 1.1 | 3.7 |
4 | 100 | 1.15 | 3.8 |
6 | 150 | 1.2 | 3.9 |
8 | 200 | 1.2 | 4 |
10 | 250 | 1.3 | 4.5 |
12 | 300 | 1.4 | 4.5 |
• Piping Systems
• Pumps
Boiling Liquids - Max Pumping Flow Velocities
Recommended max flow velocity on the delivery (pressure) side when pumping boiling liquids.
Light Oil Pumping - Flow Velocities
Recommended max. flow velocities on the delivery side when pumping light oils.
Light Oil Suction - Flow Velocities
Recommended max. suction flow velocities when pumping light oils.
Pipe Line Velocities vs. Fluid
Typical fluid flow velocities for common liquids, gases and vapors.
Pipes - Fluid Flow Velocities
Calculate fluid velocity and volume flow in pipes and tubes.
Steel Pipes - Friction Loss vs. Viscous Liquid Flow
Friction loss in schedule 40 steel pipe with viscous liquids - viscosities ranging from water to oil.
Steel Pipes Schedule 40 - Velocity Head vs. Water Flow
Velocity head can be used to calculate minor pressure or head loss in fluid flow systems.
Viscosity - Converting Chart
Recommended max. flow velocities on delivery sides of pumps in viscous systems.
Viscous Liquids - Max. Suction Flow Velocities
Recommended max. pump suction flow velocity for viscous fluids.
Water - Max. Suction Flow Velocities vs. Pipe Size
Recommended max. water flow velocities on suction sides of pumps.
Water Flow - Max. Delivery Velocities vs. Pipe Size
Recommended maximum flow velocities in water systems on the delivery side of the pump.
Water Systems - Maximum Flow Velocities
Water velocities in pipes and tubes should not exceed certain limits.
