Hydrodynamic losses through pumps depends on fluid viscosities.
Absolute (dynamic) viscosity for common food products.
Convert between Centistokes, Saybolt and Redwood seconds.
Absolute (dynamic) viscosity values for some common fluids.
Dynamic viscosities for motor oils SAE 10 to 50 for temperatures ranging 0-100 oC.
Viscosities of fuel oils vs. temperature.
Dynamic viscosities of sucrose water solutions vs. temperature.
Recommended max. flow velocities on delivery sides of pumps in viscous systems.
Recommended max. pump suction flow velocity for viscous fluids.
