Motor Oils - Dynamic Viscosities
Viscosity of lube oil is determined by the Society of Automotive Engineers (SAE).
Lube oils can be multigrade or monograde where multigrade oils fulfills two viscosity specifications. Example SAE 10W-40 where 10W refers to low-temperature - or winter - viscosity and 40 refers to the high-temperature - or summer - viscosity.
SAE
Dynamic Viscosity (N s/m2)
Temperature (oC)
02050100
10 0.31 0.079 0.020 0.005
20 0.72 0.170 0.033 0.007
30 1.53 0.310 0.061 0.010
40 2.61 0.430 0.072 0.012
50 3.82 0.630 0.097 0.015
  • 1 N s/m2 = 1 kg/(m s) = 1 Pa s = 1000 cP
Download and print Dynamic Viscosity Chart - SAE vs. temperature
Fluid Mechanics
Viscosities
Dynamic (Absolute) Viscosity - Converting Chart
Convert dynamic viscosity values between units like Poiseuille - Poise - centiPoise and more.
Engine & Gear Oil - Recommended Viscosity vs. Outside Temperature
Oil viscosity vs. temperature.
Grease - Temperature Limits
Temperature limits for grease - a combination of oil and thickener.
Industrial Lubricants - Viscosities vs. ISO-VG Grade
ISO-VG viscosity grades for industrial lubricants.
Light Oil Pumping - Flow Velocities
Recommended max. flow velocities on the delivery side when pumping light oils.
Light Oil Suction - Flow Velocities
Recommended max. suction flow velocities when pumping light oils.
Dynamic viscosities for motor oils SAE 10 to 50 for temperatures ranging 0-100 oC.
Oil Lubrication - Temperature Limits
Temperature limits for lubricating oils.
Oils - Melting points
Common oils from animals or plants and their melting points.
Viscosities and densities of SAE Grade oils.
Steel Pipes - Viscous Liquid Flow and Friction Loss
Friction loss in schedule 40 steel pipe with viscous liquids - viscosities ranging from water to oil.
Threaded Rods - Proof Loads - Metric Units
Proof load capacities of metric threaded steel rods.
Viscosity Converter: Convert Between Dynamic & Kinematic Viscosity
