Light Oil Suction - Flow Velocities
Capacity problems, cavitation and higher power consumption in pumps, are often the result of conditions on the suction sides of the pumps.
In general - as a rule of thumb - for light oils, keep the suction fluid flow speed below the following values:
Pipe boreLight Oil Velocity
inchesmmm/sft/s
1 25 0.5 1.5
2 50 0.5 1.5
3 75 0.5 1.6
4 100 0.55 1.8
6 150 0.6 2
8 200 0.7 2.3
10 250 0.9 3
12 300 0.9 3
More about NPSH suction problems can be read here:
Piping Systems
Pumps
Cavitation
Cavitation occurs in fluid flow systems where the local static pressures are below the fluids vapor pressure.
Light Oil Pumping - Flow Velocities
Recommended max. flow velocities on the delivery side when pumping light oils.
Motor Oils - Dynamic Viscosities
Dynamic viscosities for motor oils SAE 10 to 50 for temperatures ranging 0-100 oC.
Oil Pipes - Recommended Flow Velocities
Oil pipes flow velocities should be kept within certain limits.
Oil Viscosity Converter
Convert between commonly used oil viscosity units.
Pumps - Suction Head vs. Altitude
The suction head of a water pump is affected by its operating altitude.
Specific Heat of Common Liquids and Fluids
Viscous Liquids - Max. Delivery Flow Velocities
Recommended max. flow velocities on delivery sides of pumps in viscous systems.
Viscous Liquids - Max. Suction Flow Velocities
Recommended max. pump suction flow velocity for viscous fluids.
Water - Max. Suction Flow Velocities vs. Pipe Size
Recommended max. water flow velocities on suction sides of pumps.
Water Flow - Max. Delivery Velocity vs. Pipe Size
Recommended maximum flow velocities in water systems on the delivery side of the pump.
