Oil Viscosity Converter
Convert between commonly used oil kinematic viscosity units :
Convert from | Multiply with | ||||
Convert to | |||||
Poise (P) | centiPoise (cP) | Reyn | Stoke (cm2/sec) | centiStoke | |
Poise (P) | 1 | 100 | 1.45×10-5 | 1 / SG | 100 / SG |
centiPoise (cP) | 0.01 | 1 | 1.45×10-7 | 0.01 / SG | 1 / SG |
Reyn | 6.9×104 | 6.9×106 | 1 | 6.9×104/ SG | 6.9×106/ SG |
Stoke (cm2/sec) |
SG | 100 SG | 1.45×10-5 SG | 1 | 100 |
centiStoke | 0.01 SG | SG | 1.45×10-7 SG | 0.01 | 1 |
SG = specific gravity of the oil
1 Stoke = 100 mm2/second
Example - Convert Viscosity in Stokes to centiStoke
Oil with kinematic viscosity 0.1 Stoke (10 mm2/s) equals to
0.1 Stoke (100 centiStoke/Stoke) = 10 centiStokes
• Viscosities
Crude Oil Viscosity vs. Gravity
Viscosity at 20°C/68°F and 50°C/122°F for more than 120 crudes is shown as function of specific gravity@15°C/60°F.
Engine & Gear Oil - Recommended Viscosity vs. Outside Temperature
Oil viscosity vs. temperature.
Light Oil Pumping - Flow Velocities
Recommended max. flow velocities on the delivery side when pumping light oils.
Light Oil Suction - Flow Velocities
Recommended max. suction flow velocities when pumping light oils.
Liquids - Specific Gravities
Specific gravities of liquids like alcohol, oils, benzene, water and many more.
Viscosities and densities of SAE Grade oils.
Unit Factor Method
