See also Crude metal (Ni, V) content as function of gravity .
API expresses the gravity or density of liquid petroleum products. Online API to Specific Gravity calculator.
Hydrodynamic losses through pumps depends on fluid viscosities.
Content of nickel and vanadium in more than 120 crudes as function of specific gravity@15°C/60°F.
An overview of common test methods and typical ranges of variation of petroleum quality parameters. What, why and how do the different test?
An introduction to density, specific weight and specific gravity.
Convert dynamic viscosity values between units like Poiseuille - Poise - centiPoise and more.
Convert between Centistokes, Saybolt and Redwood seconds.
Absolute (dynamic) viscosity values for some common fluids.
Specific gravities for common fluids like acetone, alcohol, turpentine, oil and more.
Convert between commonly used oil viscosity units.
An overview of common test methods and specifications of petroleum fuels. What, why and how do the different test?
Yields of different crude oil distillation cuts are plotted as function of whole crude specific gravity. Fractions based on European and North American markets, and the typical differences in crude oil fractionation in the two markets are also shown.
