Dynamic (Absolute) Viscosity - Converting Chart
Fluid viscosity is an important property in the analysis of liquid behavior and fluid motion near solid boundaries.
The viscosity is fluid resistance to shear or flow and is a measure of the adhesive (cohesive) or frictional properties of a fluid. The resistance is caused by inter-molecular friction exerted when layers of fluids attempts to slide by an other.
A Dynamic or Absolute Viscosity Units Converting Table
The table below can be used to convert between common dynamic or absolute viscosity units.
Convert from | Multiply by | ||||
Convert to | |||||
Poiseuille (Pa s) | Poise (dyne s/cm2) (g/cm s) | centipoise (cP) | kg/m h | kgf s/m2 | |
Poiseuille (Pa s) |
1 | 10 | 103 | 3.63×103 | 0.102 |
0.1 | 1 | 100 | 360 | 0.0102 |
centipoise (cP) |
0.001 | 0.01 | 1 | 3.6 | 0.00012 |
kg/m h | 2.78×10-4 | 0.00278 | 0.0278 | 1 | 2.83×10-5 |
kgf s/m2 | 9.81 | 98.1 | 9.81×103 | 3.53×104 | 1 |
lbf s/inch2 | 6.89×103 | 6.89×104 | 6.89×106 | 2.48×107 | 703 |
lbf s/ft2 | 47.9 | 479 | 4.79×104 | 1.72×105 | 0.0488 |
lbf h/ft2 | 1.72×105 | 1.72×106 | 1.72×108 | 6.21×108 | 1.76×104 |
lb/ft s | 1.49 | 14.9 | 1.49×103 | 5.36×103 | 0.152 |
lb/ft h | 4.13×10-4 | 0.00413 | 0.413 | 1.49 | 4.22×10-5 |
Convert to | |||||
lbf s/inch2 | lbf s/ft2 | lbf h/ft2 | lb/ft s | lb/ft h | |
Poiseuille (Pa s) |
1.45×10-4 | 0.0209 | 5.8×10-6 | 0.672 | 2.42×103 |
1.45×10-5 | 0.00209 | 5.8×10-7 | 0.0672 | 242 |
centipoise (cP) |
1.45×10-7 | 2.09×10-5 | 5.8×10-9 | 0.000672 | 2.42 |
kg/m h | 4.03×10-8 | 5.8×10-6 | 1.61×10-9 | 0.000187 | 0.672 |
kgf s/m2 | 0.00142 | 20.5 | 5.69×10-5 | 6.59 | 2.37×104 |
lbf s/inch2 | 1 | 144 | 0.04 | 4.63×103 | 1.67×107 |
lbf s/ft2 | 0.00694 | 1 | 0.000278 | 32.2 | 1.16×105 |
lbf h/ft2 | 25 | 3.6×103 | 1 | 1.16×105 | 4.17×108 |
lb/ft s | 0.000216 | 0.0311 | 8.63×10-6 | 1 | 3.6×103 |
lb/ft h | 6 10-8 | 1.16×105 | 2.4×10-9 | 0.000278 | 1 |
Example - Converting Dynamic Viscosity from centipoise to lb/ft s
From the table above - to convert from centipoise(cP) to lb/ft s - centipoise must be multiplied with 0.000672.
10 centipoise can then be converted like
(10 centipoise) 0.000672 = 0.00672 lb/ft s
• Flow Measurements
• Viscosities
Crude Oil Viscosity vs. Gravity
Viscosity at 20°C/68°F and 50°C/122°F for more than 120 crudes is shown as function of specific gravity@15°C/60°F.
Food Products - Viscosities
Absolute (dynamic) viscosity for common food products.
Industrial Lubricants - Viscosities vs. ISO-VG Grade
ISO-VG viscosity grades for industrial lubricants.
Liquids - Dynamic Viscosities
Absolute (dynamic) viscosity values for some common fluids.
Motor Oils - Dynamic Viscosities
Dynamic viscosities for motor oils SAE 10 to 50 for temperatures ranging 0-100 oC.
Viscosities and densities of SAE Grade oils.
Sewage Sludge - Viscosities
Viscosity of sewage sludge vs. content of solids.
Viscosity Converter: Convert Between Dynamic & Kinematic Viscosity
Water - Absolute (Dynamic) Viscosity vs. Temperature and Pressure
Absolute viscosity for water in centipoises for temperatures between 32 - 200oF.
Water - Dynamic and Kinematic Viscosity at Various Temperatures and Pressures
