Sewage Sludge - Viscosities
Viscosity of sewage sludge vs. content of solids:
Solids
Viscosity
(cP)
1 10
2 80
4 560
6 1760
8 4000
10 7500
  • 1 cP = 0.01 poise = 0.01 gram per cm second = 0.001 Pascal second = 1 milliPascal second = 0.001 N s/m2
  • Viscosity Converter
Sanitary Drainage Systems
The purpose of the sanitary drainage system is to remove effluent discharged from plumbing fixtures and other equipment.
ASTM D2729 - Poly(Vinyl Chloride) (PVC) Sewer Pipe - Dimensions
Dimensions of Poly(Vinyl Chloride) (PVC) Sewer Pipes with belled end.
ASTM D3034 PSM PVC Sewer PIpe - Dimensions
Dimensions of PSM PVC sewer pipe.
Cast Iron Soil Pipes - Dimensions
Dimensions of cast iron soil pipes.
Dynamic (Absolute) Viscosity - Converting Chart
Convert dynamic viscosity values between units like Poiseuille - Poise - centiPoise and more.
Manning's Formula and Gravity Flow
Calculate cross-sectional average velocity flow in open channels.
Slurry Transports - Minimum Flow Velocities
Flow velocities in slurry transport systems to avoid settling of solids.
Viscosity Converter: Convert Between Dynamic & Kinematic Viscosity
Waste Water Piping - Flow Capacitiy vs. Dimension
In sewage piping and pumping systems the fluid flow rate must be kept within certain limits to avoid operating problems.
Water - Dynamic and Kinematic Viscosity at Various Temperatures and Pressures
