Slurry Transports - Minimum Flow Velocities
A suspension of solid particles in a liquid, as in a mixture of cement, clay, coal dust, manure, meat, etc. - with water is often called a slurry.
In transport systems for slurries it's important to avoid settling of solids by keeping the fluid velocities in the pipe lines above certain levels. The levels depends primary on the type and size of the solid in the slurry:
Type of SolidsSize of Solids
(Mesh No)
Minimum Flow Velocity
m/sft/s
Fine over 200 1 – 1.5 3 – 5
Sand 200 – 20 1.5 – 2 5 – 7
Coarse 20 – 4 2 – 3.25 7 – 11
Sludge 0.6 - 3 2 - 9
Particle Sizes
A pipeline transport system may under certain circumstances be nearly self cleaning. When a solid settle the pipe area decrease - and fluid speed increase - until a state of equilibrium where the speed is so high that settling is avoided.
Sludges with solid content less than 2 percent have hydraulic characteristics similar to water. For solids contents greater than 2 percent the friction losses are from 1.5 - 4 times the friction losses for water.
The speed should be increased in lifting lines by decreasing the piping diameter. At the end of a pipeline the speed should be slowed down by increasing the pipeline diameter.
Mesh definition
  • Mesh is the number of openings per inch of a screen - "a 100 mesh screen"
  • Mesh is often used to measures the size of particles - "100 mesh powdered sand"
  • Sieve size and mesh designation
Slope and Self Cleaning
The required slope for self cleaning of sludge pipe lines can be estimated as
Smin = τmin / (ρ Rh)                             (1)
Smin = minimum slope for self cleaning (m/m)
τmin = required shear stress for self cleaning (kg/m2) - (0.25 kg/m2 for slugde waste water, 0.15 kg/m2 for rain water)
ρ = density of fluid (kg/m3)
Rh = hydraulic diameter at maximum flow (m)
Piping Systems
Conveyors - Belt Speed
Maximum conveyor belt speed.
Conveyors - Capacities
Calculate conveyor capacities.
How to Calculate the Density of Slurries: Formula and Examples
Calculate density of a slurry.
Particle Sizes
The size of dust particles, pollen, bacteria, virus and many more.
Pipe Line Velocities vs. Fluid
Typical fluid flow velocities for common liquids, gases and vapors.
Pipe Velocity Calculator with Flow Data & Charts
Calculate fluid velocity and volume flow in pipes and tubes.
Pneumatic Powder and Solid Transport Systems
Pneumatic transport systems used to move powder and other solid products.
Pneumatic Transport and Conveying - Carrying Velocities
Recommended air velocity for pneumatic transport of products like cement, coal, flour and more.
Pneumatics - Transport of Solids and Separator Types
Separators used in pneumatic solids transport systems and their minimum particle size.
Sewage Sludge - Viscosities
Viscosity of sewage sludge vs. content of solids.
Sieve Sizes vs. Mesh Designations
US commercial sieve sizes vs. mesh designations.
Stockpile Volumes
Volume of natural stockpiles - cubic feet, yard, metre and decimetre.
Valve Selection Guide
Applications guide for selecting valves.
