Hydraulic and pneumatic systems - fluids, forces, pumps and pistons.
Maximum conveyor belt speed.
Calculate conveyor capacities.
Conveyor required power consumption vs. load.
Maximum conveyor inclination slopes for typical products.
Pneumatic transport systems used to move powder and other solid products.
Particle sizes for common products like coal, sand, ash and more.
Separators used in pneumatic solids transport systems and their minimum particle size.
US commercial sieve sizes vs. mesh designations.
Flow velocities in slurry transport systems to avoid settling of solids.
Volume of natural stockpiles - cubic feet, yard, metre and decimetre.
