Stockpile Volumes
Volumes of natural stockpiles:
Download Stockpile Volume vs. Diameter and Height Chart
Example - Stockpile Volume in Metric Units
The floor diameter of a stockpile can be measured to approximately 10 m and the height of the stockpile can be measured to approximately 4 m.
From the chart above the volume of the stockpile can be approximated to 100 m3.
Example - Stockpile Volume in Imperial Units
The floor diameter of a stockpile can be measured to approximately 10 ft and the height of the stockpile can be measured to approximately 4 ft.
From the chart above the volume of the stockpile can be approximated to 100 ft3.
  • 1 ft3 = 0.02832 m3 = 28.32 dm3 = 0.03704 yd3
  • 1 ft (foot) = 0.3048 m = 12 in = 0.3333 yd
Download and print Stockpile Height vs. Diameter and Angle of Repose Chart
Mass of a Pile
The mass of a pile can be calculated as
m = ρ V                              (1)
m = mass (kg, lb)
ρ = density of the volume in the pile (kg/m3, lb/ft3)
V = stockpiled volume (m3, ft3)
For density - be aware of the bulking factor for the stockpiled material.
Example - Stockpiled Anthracite Coal
Anthracite coal with density 65 lb/ft 3 is stockpiled in a conical pile with diameter 30 ft and height 8 ft .
According the diagram above the volume of the pile is approximately 2000 ft3 .
The total mass of the pile can be calculated as
w = (65 lb/ft3) (2000 ft3)
= 130000 lb
Calculator - Volume of a Coned Pile
The calculator below can be used to calculate volume and mass of a coned pile.
Calculator - Volume of a Rectangular Pile
The calculator below can be used to calculate volume and mass of a rectangular pile.
Miscellaneous
Angles of Repose
Tipping or dumping angles for common materials like ashes, sand, earth, shingles and more.
Conveyors - Capacities
Calculate conveyor capacities.
Conveyors - Load & Power Consumption
Conveyor required power consumption vs. load.
Conveyors - Maximum Inclination vs. Product
Maximum conveyor inclination slopes for typical products.
Cooking Units Volume Converter - U.S. and Metric Units
Convert between cooking liquid and dry measuring US and metric volume units.
Cooking Volumes - U.S. Unit Converter
Convert between US cooking volume units.
How to Calculate the Density of Slurries: Formula and Examples
Calculate density of a slurry.
Pneumatic Powder and Solid Transport Systems
Pneumatic transport systems used to move powder and other solid products.
Pneumatic Powder Transport
An introduction to pneumatic transport of powders.
Pneumatic Transport - Solids and Particle Size
Particle sizes for common products like coal, sand, ash and more.
Pneumatic Transport and Conveying - Carrying Velocities
Recommended air velocity for pneumatic transport of products like cement, coal, flour and more.
Pneumatics - Transport of Solids and Separator Types
Separators used in pneumatic solids transport systems and their minimum particle size.
Sieve Sizes vs. Mesh Designations
US commercial sieve sizes vs. mesh designations.
Slurry Transports - Minimum Flow Velocities
Flow velocities in slurry transport systems to avoid settling of solids.
Soil and Rock - Bulk Factors
Solids - Densities
Densities of selected solids.
Stones - Weight and Strength
Weight and strength of sandstone, granite, limestone, marble and slate.
