Solids - Densities
Density of solids:
| Solid | Density (10³ kg/m³) |
| ABS - copolymer of acrylonitrile, butadiene and styrene | 1.06 |
| Acetals | 1.42 |
| Agate | 2.5 - 2.7 |
| Acrylic | 1.19 |
| Agate | 2.6 |
| Alabaster carbonate | 2.7 - 2.8 |
| Alabaster sulfate | 2.3 |
| Alum, lumpy | 0.881 |
| Alum, pulverized | 0.752 |
| Alumina (aluminium oxide) | 3.95 - 4.1 |
| Aluminum | 2.7 |
| Aluminum Alloys | 2.6 - 2.85 |
| Aluminum Bronze | 7.7 |
| Albite | 2.6 - 2.65 |
| Alloys | |
| Amber | 1.06 - 1.1 |
| Amphiboles | 2.9 - 3.2 |
| Andesite, solid | 2.77 |
| Anorthite | 2.74 - 2.76 |
| Antimony, cast | 6.7 |
| Arsenic | 4.7 |
| Artificial Wool | 1.5 |
| Asbestos | 2.0 - 2.8 |
| Asbestos, shredded | 0.35 |
| Asbestos, solid | 2.45 |
| Ashes | 0.65 |
| Asphalt, compacted | 2.36 |
| Asphalt, crushed | 0.72 |
| Bakelite | 1.36 |
| Baking powder | 0.72 |
| Balsa Wood | 0.13 |
| Barite, crushed | 2.89 |
| Barium | 3.78 |
| Barium chloride | 3.86 |
| Bark, wood refuse | 0.24 |
| Barytes | 4.5 |
| Basalt | 2.4 - 3.1 |
| Bauxite, crushed | 1.28 |
| Beef tallow | 0.9 - 0.97 |
| Beeswax | 0.96 |
| Beryl | 2.7 |
| Beryllia | 3.0 |
| Beryllium | 1.85 |
| Biotite | 2.7 - 3.1 |
| Bismuth | 9.8 |
| Bitumen | 1.05 |
| Boiler scale | 2.5 |
| Bone | 1.7 - 2.0 |
| Bone, pulverized | 0.88 |
| Borax, fine | 0.85 |
| Boron | 2.34 |
| Brasses | 8.4 - 8.75 |
| Bronzes | 8.74 - 8.89 |
| Brown iron ore | 5.1 |
| Brick | 1.4 - 2.4 |
| Brick, fire | 2.3 |
| Brick, hard | 2 |
| Brick, pressed | 2.2 |
| Brickwork in cement | 1.8 |
| Brickwork in mortar | 1.6 |
| Butter | 0.86 - 0.87 |
| Cadmium | 8.64 |
| Calamine | 4.1 - 4.5 |
| Calcium | 1.55 |
| Calsium chloride | 2.15 |
| Calcspar | 2.6 - 2.8 |
| Camphor | 1 |
| Carbon | 3.51 |
| Caoutchouc | 0.9 - 1 |
| Cardboard | 0.7 |
| Cast Iron | 7.2 |
| Celluloid | 1.4 |
| Cellulose, cotton, wood pulp, regenerated | 1.48 - 1.53 |
| Cellulose acetat, moulded | 1.22 - 1.34 |
| Cellulose acetat, sheet | 1.28 - 1.32 |
| Cellulose nitrate, celluloid | 1.35 - 1.4 |
| Chlorinated polyether | 1.4 |
| Cement, set | 2.7 - 3 |
| Cement, Portland | 1.5 |
| Cerium | 6.77 |
| Chalk | 1.9 - 2.8 |
| Chamotte, fireclay | 1.7 - 2.4 |
| Charcoal, oak | 0.6 |
| Charcoal, pine | 0.3 - 0.4 |
| Chromium | 7.1 |
| Chrom oxide | 5.21 |
| Cinnabar | 8.1 |
| Clay | 1.8 - 2.6 |
| Coal, anthracite | 1.4 - 1.8 |
| Coal, bituminous | 1.2 - 1.5 |
| Cobalt | 8.8 |
| Cocoa, butter | 0.9 |
| Coke | 1.6 - 1.9 |
| Concrete, lightweight | 0.45 - 1.0 |
| Concrete, medium | 1.3 - 1.7 |
| Concrete, dense | 2.0 - 2.4 |
| Constantan | 8.89 |
| Copal | 1 - 1.15 |
| Copper | 8.79 |
| Cork | 0.2 - 0.25 |
| Cork, linoleum | 0.55 |
| Corundum | 4.0 |
| Cotton | 0.08 |
| CPVC - Chlorinated poly vinyl chloride | 1.6 |
| Lead Crystal | 3.1 |
| Diamond | 3 - 3.5 |
| Dolomite | 2.8 |
| Duralium | 2.8 |
| Earth, loose | 1.2 |
| Earth, rammed | 1.6 |
| Ebonite | 1.15 |
| Emery | 4 |
| Electron | 1.8 |
| Epidote | 3.2 - 3.5 |
| Epoxy cast resin | 1.11 - 1.4 |
| Epoxy glass fibre | 1.5 |
| Expanded polystyrene | 0.015 - 0.03 |
| Feldspar | 2.6 - 2.8 |
| Fire brick | 1.8 - 2.2 |
| Flint | 2.6 |
| Fluorite | 3.2 |
| Galena | 7.3 - 7.6 |
| Gallium | 5.9 |
| Gamboge | 1.2 |
| Garnet | 3.2 - 4.3 |
| Gas carbon | 1.9 |
| Gelatin | 1.3 |
| Germanium | 5.32 |
| Glass, common | 2.4 - 2.8 |
| Glass, flint | 2.9 - 5.9 |
| Glass, Pyrex | 2.21 |
| Glass-wool | 0.025 |
| Glue | 1.3 |
| Gneiss | 2.69 |
| Gold | 19.29 |
| Granite | 2.6 - 2.8 |
| Graphite | 2.3 - 2.7 |
| Gum arabic | 1.3 - 1.4 |
| Gypsum | 2.3 |
| Hardboard | 1.0 |
| Hematite | 4.9 - 5.3 |
| Hornblende | 3 |
| Ice | 0.917 |
| Indium | 7.29 |
| Iron, cast | 7.0 - 7.4 |
| Iodine | 4.95 |
| Iridium | 22.5 |
| Ivory | 1.8 - 1.9 |
| Kaolin | 2.6 |
| Lead | 11.35 |
| Leather, dry | 0.86 |
| Lime, slaked | 1.35 |
| Limestone | 2.7 -2.8 |
| Linoleum | 1.2 |
| Lithium | 0.53 |
| Magnesia | 3.2 - 3.6 |
| Magnesium | 1.74 |
| Magnetite | 4.9 - 5.2 |
| Malachite | 3.7 - 4.1 |
| Manganese | 7.43 |
| Marble | 2.6 - 2.8 |
| Meerschaum | 1 - 1.3 |
| Metals | |
| Mica | 2.6 - 3.2 |
| Mineral wool quilt | 0.05 |
| Molybdenum | 10.2 |
| Muscovite | 2.8 - 3 |
| Nickel | 8.9 |
| Nylon 6 | 1.12 - 1.17 |
| Nylon 6,6 | 1.13 - 1.15 |
| Oak | 0.72 |
| Ochre | 3.5 |
| Opal | 2.2 |
| Osmium | 22.48 |
| Palladium | 12.0 |
| Paper | 0.7 - 1.15 |
| Paraffin | 0.9 |
| Peat blocks | 0.85 |
| Phenolic cast resin | 1.24 - 1.32 |
| Phosphorbronce | 8.8 |
| Phosphorus | 1.82 |
| Pinchbeck | 8.65 |
| Pitch | 1.1 |
| Pit coal | 1.35 |
| Plaster board | 0.80 |
| Platinum | 21.5 |
| Plywood | 0.54 |
| Polyacrylonitrile | 1.16 - 1.18 |
| Polyamides | 1.15 - 1.25 |
| PC - poly carbonate | 1.2 |
| PBT - poly butylene terephthalate | 1.35 |
| LDPE - low density poly ethylene | 0.91 |
| HDPE - (PEH) - high density poly ethylene | 0.96 |
| PET - poly ethylene terephthalate | 1.35 |
| PMMA - poly methyl methacrylate | 1.2 |
| POM - poly oxy methylene | 1.4 |
| PP - poly propylene | 0.91 - 0.94 |
| PPO - poly penylene ether | 1.1 |
| PS - poly styrene | 1.03 |
| PTFE - poly tetra fluoro ethylene, Teflon | 2.28 - 2.30 |
| PU - poly urethane foam | 0.03 |
| PVDF - poly vinylidene fluoride | 1.76 |
| Porcelain | 2.3 - 2.5 |
| Porphyry | 2.6 - 2.9 |
| Potassium | 0.86 |
| Pressed wood, pulp board | 0.19 |
| PVC - poly vinyl chloride | 1.39 - 1.42 |
| Pyrex | 2.25 |
| Pyrite | 4.9 - 5.1 |
| Quartz | 2.65 |
| Radium | 5 |
| Red lead | 8.6 - 9.1 |
| Red metal | 8.8 |
| Resin | 1.07 |
| Rhenium | 21.4 |
| Rhodium | 12.3 |
| Rock salt | 2.2 |
| Rock wool | 0.22 - 0.39 |
| Rosin | 1.07 |
| Rubber, hard | 1.2 |
| Rubber, soft commercial | 1.1 |
| Rubber, pure gum | 0.91 - 0.93 |
| Rubber, foam | 0.06 - 0.25 |
| Rubidium | 1.52 |
| Sand, dry | 1.4 - 1.6 |
| Sandstone | 2.1 - 2.4 |
| Sapphire | 3.98 |
| Selenium | 4.4 |
| Serpentine | 2.5 - 2.65 |
| Silica, fused transparent | 2.2 |
| Silica, translucent | 2.1 |
| Silicium carbide | 3.16 |
| Silicon | 2.33 |
| Silver | 10.5 |
| Slag | 2 - 3.9 |
| Slate | 2.6 - 3.3 |
| Snow | 0.1 |
| Soapstone | 2.6 - 2.8 |
| Sodium | 0.98 |
| Soil | 2.05 |
| Solder | 8.7 - 9.4 |
| Soot | 1.6 - 1.7 |
| Spermaceti | 0.95 |
| Starch | 1.5 |
| Steatite | 2.6 - 2.7 |
| Steel | 7.82 |
| Stone | 2.3 - 2.8 |
| Sulfur, cryst. | 2.0 |
| Sugar | 1.6 |
| Talc | 2.7 - 2.8 |
| Tallow, beef | 0.95 |
| Tallow, mutton | 0.95 |
| Tantalum | 16.6 |
| Tar | 1.05 |
| Teflon | 2.20 |
| Tellurium | 6.25 |
| Thoria | 4.16 |
| Thorium | 11.7 |
| Timber | |
| Tin | 7.28 |
| Titanium | 4.5 |
| Tombac | 8.65 |
| Topaz | 3.5 - 3.6 |
| Tourmaline | 3 - 3.2 |
| Tungsten | 19.2 |
| Tungsten carbide | 14.0 - 15.0 |
| Uranium | 19.1 |
| Urethane foam (Urea formaldehyde foam) | 0.08 |
| Vanadium | 6.1 |
| Vermiculite | 0.12 |
| Wax, sealing | 1.8 |
| White metal | 7.5 - 10 |
| Wood (seasoned) | |
| Wood wool slab | 0.5 - 0.8 |
| Zinc | 7.12 |
| Zirconium | 6.51 |
- 1 kg/m3 = 0.001 g/cm3 = 0.0005780 oz/in3 = 0.16036 oz/gal (Imperial) = 0.1335 oz/gal (U.S.) = 0.0624 lb/ft3 = 0.000036127 lb/in3 = 1.6856 lb/yd3 = 0.010022 lb/gal (Imperial) = 0.008345 lb/gal (U.S) = 0.0007525 ton/yd3
* Note that even if pounds per cubic foot is often used as a measure of density in the U.S., pounds are really a measure of force, not mass. Slugs are the correct measure of mass. You can divide pounds per cubic foot by 32.2 for a rough value in slugs.
• Densities
ABS Pipes - Pressure Ratings
Pressure ratings of ABS 1208, ABS 1210, ABS 1316 and ABS 2112.
Angles of Repose
Tipping or dumping angles for common materials like ashes, sand, earth, shingles and more.
Bricks - Quantity and Mortar Consumption
Estimate required quantities of bricks and mortar.
Density of Wood Species: Data & Material Guide
Hydrocarbons - Physical Data
Liquid Densities
Mass vs Weight
Metals and Alloys - Densities
Minerals - Densities
Densities of minerals.
Minerals and other Materials - Specific Gravities
Specific gravities for minerals and other materials.
Mortar Types
ASTM mortar types.
Soil - Earth Weight and Composition
Typical weight and composition of soil.
Soil and Rock - Bulk Factors
Solids - Melting and Boiling Temperatures
Melting and boiling temperatures of some products.
Stockpile Volumes
Volume of natural stockpiles - cubic feet, yard, metre and decimetre.
Stone Masonry - Strength
Typical strength of stone masonry constructions.
Stones - Weight and Strength
Weight and strength of sandstone, granite, limestone, marble and slate.
