Mortar Types
Minimum required compressive strength and material quantities in mortar according ASTM C 270:
Mortar Types
ASTM Mortar Type
M S N O
Strength (psi) 2500 1800 750 350
Volume Ratio 1:1/4:3 1:1/2:4 1/2 1:1:6 1:2:9
Proportions by Volume
Cement 0.33 0.22 0.17 0.11
Lime 0.08 0.11 0.17 0.22
Sand 1 1 1 1
Proportions by Weight
Cement 31.3 20.9 15.7 10.4
Lime 3.3 4.4 6.7 8.9
Sand 80 80 80 80
Miscellaneous
Bricks - Quantity and Mortar Consumption
Estimate required quantities of bricks and mortar.
Compression and Tension Strength of some common Materials
Common materials and average ultimate compression and tension strength.
Concrete - Water to Cement Ratios
Water vs. cement ratio when mixing concrete.
Concrete Mixtures
Cement, sand and gravel mixtures.
Concrete Properties
Properties of normal strength Portland cement concrete.
Concrete Slabs - Load Capacities
Load capacity of simply supported concrete slabs.
Solids - Densities
Densities of selected solids.
Solids - Specific Heats
Thermal Conductivity of Common Materials - Solids, Liquids and Gases
Thermal conductivity of various common materials, including metals, gases, and building materials. Essential data for engineers, architects, and designers working with heat transfer and insulation.
