Concrete Properties
Typical properties of normal strength Portland cement concrete:
Material Properties
ACI - American Concrete Institute
American Concrete Institute.
Bricks - Quantity and Mortar Consumption
Estimate required quantities of bricks and mortar.
Building Foundations - Loads
Typical loads on building foundations.
Compression and Tension Strength of some common Materials
Common materials and average ultimate compression and tension strength.
Concrete - Calculating Cubic Volume
Calculating the concrete volume required for an operation.
Concrete Columns
Estimate concrete volume required for concrete columns.
Concrete Footings - Volume
Estimate required concrete footing volume.
Concrete Mixtures
Cement, sand and gravel mixtures.
Concrete Properties
Properties of normal strength Portland cement concrete.
Concrete Properties
Concrete Slabs - Load Capacities
Load capacity of simply supported concrete slabs.
Concrete Slabs - Required Thickness
Required thickness of concrete slabs.
Concrete Slabs - Volume Estimates
Estimate required concrete volume per sq. ft.
Concrete Walls - Volume
Estimate concrete wall volume.
Earth Pressure Acting on Basement Walls
Calculate lateral earth pressure acting on basement walls.
Masonry Blocks - Dimensions
Concrete Masonry Unit Blocks (CMU) - dimensions.
The Bulk Modulus - resistance to uniform compression - for some common metals and alloys.
Mortar Types
ASTM mortar types.
