Concrete Footings - Volume
Concrete is in general calculated in cubic yards - cy. Required concrete for footing can be calculated as
v =  0.0031 l w t                                   (1)
v = required concrete - cy (cu. yards)
l = length of footing (ft)
w = width of footing (ft)
t = depth of footing (in)
  • 1 cy (cubic yard) = 27 cubic feet
  • 1 ft = 12 in
Concrete Volume - CY per Linear Foot of Footing
Depth of Footing
(in)
Concrete Volume
(cy per linear foot of footing)
Width of footing (in)
12151824
6 0.019 0.023 0.028 0.037
8 0.025 0.031 0.037 0.049
9 0.028 0.035 0.042 0.056
10 0.031 0.039 0.046 0.062
12 0.037 0.046 0.056 0.074
18 0.056 0.069 0.083 0.111
24 0.074 0.093 0.111 0.148
30 0.093 0.116 0.139 0.185
36 0.111 0.139 0.167 0.222
42 0.130 0.162 0.194 0.259
  •  1 cy per linear foot (y3/ft) = 2.5 m3/m
Miscellaneous
ACI - American Concrete Institute
American Concrete Institute.
Building Foundations - Loads
Typical loads on building foundations.
Concrete - Calculating Cubic Volume
Calculating the concrete volume required for an operation.
Concrete - Water to Cement Ratios
Water vs. cement ratio when mixing concrete.
Concrete Columns
Estimate concrete volume required for concrete columns.
Concrete Mixtures
Cement, sand and gravel mixtures.
Concrete Properties
Properties of normal strength Portland cement concrete.
Concrete Slabs - Load Capacities
Load capacity of simply supported concrete slabs.
Concrete Slabs - Required Thickness
Required thickness of concrete slabs.
Concrete Slabs - Volume Estimates
Estimate required concrete volume per sq. ft.
Concrete Walls - Volume
Estimate concrete wall volume.
Earth Pressure Acting on Basement Walls
Calculate lateral earth pressure acting on basement walls.
Gravel - Cover Area
Gravel aggregate covering area.
Masonry Blocks - Dimensions
Concrete Masonry Unit Blocks (CMU) - dimensions.
Rebar - Metric Reinforcing Bar
Reinforcing bar - European metric dimensions.
Rebar - U.S. Imperial Reinforcing Bar
U.S. imperial dimensions of rebar
Rebars - Weights
Weights of rebar rods - size ranging 1/4.
