Rebar - Metric Reinforcing Bar
Bar Number | Mass (kg/m) | Nominal Diameter (mm) | Cross Sectional Area (mm2) |
10M | 0.785 | 11.3 | 100 |
15M | 1.570 | 16.0 | 200 |
20M | 2.355 | 19.5 | 300 |
25M | 3.925 | 25.2 | 500 |
30M | 5.495 | 29.9 | 700 |
35M | 7.850 | 35.7 | 1000 |
45M | 11.775 | 43.7 | 1500 |
55M | 19.625 | 56.4 | 2500 |
Concrete Columns
Estimate concrete volume required for concrete columns.
Concrete Footings - Volume
Estimate required concrete footing volume.
Concrete Mixtures
Cement, sand and gravel mixtures.
Concrete Slabs - Required Thickness
Required thickness of concrete slabs.
Concrete Slabs - Volume Estimates
Estimate required concrete volume per sq. ft.
Earth Pressure Acting on Basement Walls
Calculate lateral earth pressure acting on basement walls.
Weight of round bars.
Rebar - U.S. Imperial Reinforcing Bar
U.S. imperial dimensions of rebar
Rebars - Weights
Weights of rebar rods - size ranging 1/4.
Steel Wool - Grades
Steel wool grades vs. fiber thickness.
