Steel Wool - Grades
Steel wool is made by shaving thin layers of steel from wires.
Steel wool consists of long and relatively strong shavings with sharp edges.
Steel Wool | Grade | Fiber Thickness | |
(inches) | (mm) | ||
Super Fine | 0000 | 0.001 | 0.025 |
Extra Fine | 000 | 0.0015 | 0.035 |
Very Fine | 00 | 0.0018 | 0.04 |
Fine | 0 | 0.002 | 0.05 |
Medium | 1 | 0.0025 | 0.06 |
Medium Coarse | 2 | 0.003 | 0.075 |
Coarse | 3 | 0.0035 | 0.09 |
Extra Coarse | 4 | 0.004 | 0.10 |
Weight of round bars.
Mild Steel - Square Bars Weight
Typical weights of mild steel square bars.
Rebar - Metric Reinforcing Bar
Reinforcing bar - European metric dimensions.
Steel Flats - Weights
Steel Plate Weight Guide: Calculator & Data Table
Wire Ropes - Strengths
6 strand x 19 wire (6x19) - minimum breaking strength, safe loads and weight.
