Weight of mild steel round bars can be calculated as
W = 0.0062 d2 (1)
W = weight (kg/m)
d = round diameter (mm)
Bar Diameter (mm) | Weight (kg/m) |
6 | 0.22 |
8 | 0.39 |
10 | 0.62 |
12 | 0.89 |
16 | 1.58 |
20 | 2.47 |
25 | 3.85 |
32 | 6.31 |
40 | 9.86 |
45 | 12.5 |
50 | 15.4 |
60 | 22.2 |
65 | 26.0 |
75 | 34.7 |
90 | 49.9 |
100 | 61.6 |
Mild Steel - Square Bars Weight
Typical weights of mild steel square bars.
Rebar - Metric Reinforcing Bar
Reinforcing bar - European metric dimensions.
Rebar - U.S. Imperial Reinforcing Bar
U.S. imperial dimensions of rebar
Rebars - Weights
Weights of rebar rods - size ranging 1/4.
Shafts Torsion
The torsion of solid or hollow shafts - Polar Moment of Inertia of Area.
Solids - Volumes and Surfaces
The volume and surface of solids like rectangular prism, cylinders, pyramids, cones and spheres - online calculator.
Steel Flats - Weights
Steel Plate Weight Guide: Calculator & Data Table
Steel Wool - Grades
Steel wool grades vs. fiber thickness.
Threaded Rods - Loads in Imperial Units
Weight rating of threaded hanger rods.
