Rebar - U.S. Imperial Reinforcing Bar
| Bar No. | Weight (lb/ft) | Nominal Diameter (in) | Nominal Diameter (mm) | Nominal Area (in2) | Nominal Area (mm2) |
| 2 | 0.166 | 0.25 = 1/4 | 6.4 | 0.05 | 32 |
| 3 | 0.376 | 0.375 = 3/8 | 9.525 | 0.11 | 71 |
| 4 | 0.668 | 0.500 = 1/2 | 12.7 | 0.20 | 129 |
| 5 | 1.043 | 0.625 = 5/8 | 15.875 | 0.31 | 200 |
| 6 | 1.502 | 0.750 = 3/4 | 19.05 | 0.44 | 284 |
| 7 | 2.044 | 0.875 = 7/8 | 22.225 | 0.60 | 387 |
| 8 | 2.670 | 1.000 = 1 | 25.4 | 0.79 | 509 |
| 9 | 3.400 | 1.128 = 1 1/8 | 28.65 | 1.00 | 645 |
| 10 | 4.303 | 1.270 = 1 1/4 | 32.26 | 1.27 | 819 |
| 11 | 5.313 | 1.410 = 1 3/8 | 35.81 | 1.56 | 1006 |
| 14 | 7.650 | 1.693 = 1 3/4 | 43 | 2.25 | 1452 |
| 18 | 13.60 | 2.257 = 2 1/4 | 57.33 | 4.00 | 2581 |
Concrete Columns
Estimate concrete volume required for concrete columns.
Concrete Footings - Volume
Estimate required concrete footing volume.
Concrete Mixtures
Cement, sand and gravel mixtures.
Concrete Slabs - Required Thickness
Required thickness of concrete slabs.
Concrete Slabs - Volume Estimates
Estimate required concrete volume per sq. ft.
Weight of round bars.
Rebar - Metric Reinforcing Bar
Reinforcing bar - European metric dimensions.
Rebars - Weights
Weights of rebar rods - size ranging 1/4.
