Concrete Slabs - Volume Estimates
Required concrete is in general calculated in cubic yards (cy).
v =  0.0031 l w t                               (1)
v = required concrete - (cy, cu. yards)
l = slab length (ft)
w = slab width (ft)
t = slab depth (in)
  • 1 cubic yard = 27 cubic feet
  • 1 ft = 12 in
Slab Concrete Volume
Depth
(in)
Volume
(cy/sq.ft.)
2 0.006
4 0.012
6 0.019
8 0.024
10 0.031
  • 1 in (inch) = 25.4 mm = 2.54 cm = 0.0254 m
  • 1 yd3 = 0.7646 m3
  • 1 ft2 = 0.0929 m2
Area Covered by Concrete
The table below shows the area (sq.ft.) that 1 cu. yard of concrete will cover for various depths.
Concrete Slabs - Covered Area Estimates
Depth
(in)
Area
(sq.ft.)
2 162
3 108
4 81
5 65
6 54
7 46.3
8 40.5
9 36
10 32.4
11 29.5
12 27
Concrete required for concrete slabs can be estimated below:
Miscellaneous
ACI - American Concrete Institute
American Concrete Institute.
Concrete - Calculating Cubic Volume
Calculating the concrete volume required for an operation.
Concrete - Water to Cement Ratios
Water vs. cement ratio when mixing concrete.
Concrete Columns
Estimate concrete volume required for concrete columns.
Concrete Footings - Volume
Estimate required concrete footing volume.
Concrete Mixtures
Cement, sand and gravel mixtures.
Concrete Properties
Properties of normal strength Portland cement concrete.
Concrete Slabs - Load Capacities
Load capacity of simply supported concrete slabs.
Concrete Slabs - Required Thickness
Required thickness of concrete slabs.
Concrete Walls - Volume
Estimate concrete wall volume.
Earth Pressure Acting on Basement Walls
Calculate lateral earth pressure acting on basement walls.
Gravel - Cover Area
Gravel aggregate covering area.
Masonry Blocks - Dimensions
Concrete Masonry Unit Blocks (CMU) - dimensions.
Rebar - Metric Reinforcing Bar
Reinforcing bar - European metric dimensions.
Rebar - U.S. Imperial Reinforcing Bar
U.S. imperial dimensions of rebar
Rebars - Weights
Weights of rebar rods - size ranging 1/4.
