Concrete Columns
Concrete is in general calculated in cubic yards (cy).
The concrete required for a column can be calculated as
v = 0.7854 a2 h / 27 (1)
v = required concrete - cy (cu. yards)
a = column area (sq. ft.)
h = column height (ft)
- 1 cubic yard = 27 cubic feet
- 1 ft = 12 in
Concrete required per 1 ft Column Height
Column Size (in) | Volume (cy - cubic yards - per linear foot Round Column) |
8 | 0.013 |
9 | 0.016 |
10 | 0.020 |
11 | 0.024 |
12 | 0.029 |
14 | 0.040 |
16 | 0.051 |
18 | 0.065 |
20 | 0.081 |
22 | 0.097 |
24 | 0.116 |
26 | 0.137 |
28 | 0.158 |
30 | 0.181 |
Column Size (in x in) | Volume (cy - cubic yards - per linear foot Square Column) |
12 x 12 | 0.037 |
13 x 13 | 0.043 |
14 x 14 | 0.050 |
15 x 15 | 0.058 |
16 x 16 | 0.066 |
17 x 17 | 0.074 |
18 x 18 | 0.083 |
19 x 19 | 0.093 |
20 x 20 | 0.103 |
21 x 21 | 0.113 |
22 x 22 | 0.124 |
23 x 23 | 0.136 |
24 x 24 | 0.148 |
25 x 25 | 0.161 |
26 x 26 | 0.174 |
27 x 27 | 0.188 |
28 x 28 | 0.202 |
29 x 29 | 0.216 |
30 x 30 | 0.231 |
- 1 cu yd per linear foot (y3/ft) = 2.5 m3/m
Concrete - Calculating Cubic Volume
Calculating the concrete volume required for an operation.
Concrete - Water to Cement Ratios
Water vs. cement ratio when mixing concrete.
Concrete Footings - Volume
Estimate required concrete footing volume.
Concrete Mixtures
Cement, sand and gravel mixtures.
Concrete Properties
Properties of normal strength Portland cement concrete.
Concrete Slabs - Load Capacities
Load capacity of simply supported concrete slabs.
Concrete Slabs - Required Thickness
Required thickness of concrete slabs.
Concrete Slabs - Volume Estimates
Estimate required concrete volume per sq. ft.
Concrete Walls - Volume
Estimate concrete wall volume.
Euler Column Buckling: Formula, Theory & Calculator
Calculate buckling of columns.
Masonry Blocks - Dimensions
Concrete Masonry Unit Blocks (CMU) - dimensions.
Rebar - Metric Reinforcing Bar
Reinforcing bar - European metric dimensions.
Rebar - U.S. Imperial Reinforcing Bar
U.S. imperial dimensions of rebar
Rebars - Weights
Weights of rebar rods - size ranging 1/4.
Steel Pipe Columns - Allowable Loads
Allowable concentric loads for steel pipe columns.
