Concrete - Water to Cement Ratios
Water to cement ratio is the ratio of
weight of water to the weight of cement
used in a concrete mix and can be expressed as
r = wh20 / wc
  = 8.33 qH20 / wc                             (1)
r = water to cement ratio
wh20 = weight of water (lbs)
w= weight of cement (lbs)
qH20 = volume of water (US gallon)
Example - Water to Cement Ratio
A batch of concrete has 45 gallons of water and 900 lbs of cement. The water to cement ratio can be calculated as
r = 8.33 (45 gallons) / (900 lbs)
  = 0.42
Miscellaneous
ACI - American Concrete Institute
American Concrete Institute.
Bricks - Quantity and Mortar Consumption
Estimate required quantities of bricks and mortar.
Concrete - Calculating Cubic Volume
Calculating the concrete volume required for an operation.
Concrete Columns
Estimate concrete volume required for concrete columns.
Concrete Footings - Volume
Estimate required concrete footing volume.
Concrete Slabs - Load Capacities
Load capacity of simply supported concrete slabs.
Concrete Slabs - Required Thickness
Required thickness of concrete slabs.
Concrete Slabs - Volume Estimates
Estimate required concrete volume per sq. ft.
Masonry Blocks - Dimensions
Concrete Masonry Unit Blocks (CMU) - dimensions.
Mortar Types
ASTM mortar types.
