Insulation
Heat transfer and heat loss from buildings and technical applications - heat transfer coefficients and insulation methods to reduce energy consumption.
Building Elements - Heat Loss vs. Thermal Resistivity
Thermal resistance in building elements like walls, floors and roofs above and below the ground.
Building Materials - Vapour Resistance
Diffusion of vapor through building materials.
Calcium Silicate Insulation
Thermal conductivity of calcium silicate insulation - temperature and k-values.
Conductive Heat Transfer
Copper Tubes - Uninsulated Heat Losses
Heat loss from uninsulated copper pipes - dimensions ranging 1/2 - 4 inches.
Duct Wrap Insulation - Thermal Resistance
Heat flow thermal resistance of unfaced and faced duct wrap insulation.
Fiberglass Insulation
Thermal conductivity of fiberglass insulation - temperature and k-values.
Heat Traced Pipes - Wrapping Factor
Wrapping factor when the heat loss from a pipe or tube is higher than the capacity of the heat trace cable.
Insulated Copper Tubes - Heat Loss
Heat loss to surrounding air from insulated copper tubes.
Insulation Materials - Operating Temperature Limits
Temperature limits for commonly used insulation materials.
Insulation of Cooling Systems
Cooling systems and insulation thickness.
Mineral Wool Insulation
Overall Heat Transfer Coefficients
Perlite Insulation
Pipes - Bare Surface Heat Loss
Heat loss vs. surface temperature.
Pipes - Insulated Heat Loss Diagrams
Heat loss (W/m) from 1/2 to 6 inches insulated pipesĀ - ranging insulation thickness 10 to 80 mm and temperature differences 20 to 180 oC.
Heat loss (W/ft) diagrams for 1/2 to 6 inches insulated pipesĀ - ranging insulation thickness 0.5 to 4 inches and temperature differences 50 to 350 oF.
Pipes and Cylinders - Conductive Heat Losses
Conductive heat losses through cylinder or pipe walls.
Piping - Recommended Insulation Thickness
Recommended insulation thickness for heating systems like hot water and low, medium or high pressure steam systems.
Polyurethane Insulation
Radiation - Surfaces Emissivity Coefficients
Radiation emissivity of common materials like water, ice, snow, grass and more.
Radiation Heat Transfer
Thermal conductivity coefficients for insulation materials, aluminum, asphalt, brass, copper, steel, gases and more.
Steel Pipes - Heat Loss Diagram
Heat loss from steel pipes and tubes - dimensions 1/2 to 12 inches.
