Thermal Conductivity of Common Materials - Solids, Liquids and Gases
Thermal conductivity is a material property that describes ability to conduct heat . Thermal conductivity can be defined as
Thermal conductivity units are (W/(m K)) in the SI system and (Btu/(hr ft °F)) in the Imperial system.
See also thermal conductivity variations with temperature and pressure , for: Air, Ammonia, Carbon Dioxide and Water
Thermal conductivities for common materials and products:
| Material/Substance | Thermal Conductivity - k - W/(m K) | ||
| Temperature | |||
| 25 oC (77 oF) | 125 oC (257 oF) | 225 oC (437 oF) | |
| Acetals | 0.23 | ||
| Acetals | 0.23 | ||
| Acetone | 0.16 | ||
| Acetylene (gas) | 0.018 | ||
| Acrylic | 0.2 | ||
| Air, atmosphere (gas) | 0.0262 | 0.0333 | 0.0398 |
| Air, elevation 10000 m | 0.020 | ||
| Agate | 10.9 | ||
| Alcohol | 0.17 | ||
| Alumina | 36 | 26 | |
| Aluminum | |||
| Aluminum Brass | 121 | ||
| Aluminum Oxide | 30 | ||
| Ammonia (gas) | 0.0249 | 0.0369 | 0.0528 |
| Antimony | 18.5 | ||
| Apple (85.6% moisture) | 0.39 | ||
| Argon (gas) | 0.016 | ||
| Arsenic | 50 | ||
| Asbestos-cement board1) | 0.744 | ||
| Asbestos-cement sheets1) | 0.166 | ||
| Asbestos-cement1) | 2.07 | ||
| Asbestos, loosely packed1) | 0.15 | ||
| Asbestos mill board1) | 0.14 | ||
| Asphalt | 0.75 | ||
| Balsa wood | 0.048 | ||
| Barium | 18.4 | ||
| Basalt | 1.67 | ||
| Beryllium | 200 | ||
| Bismuth | 8.1 | ||
| Bitumen | 0.17 | ||
| Bitumen/felt layers | 0.5 | ||
| Beef, lean (78.9 % moisture) | 0.43 - 0.48 | ||
| Benzene | 0.16 | ||
| Beryllium | |||
| Bismuth | 8.1 | ||
| Bitumen | 0.17 | ||
| Blast furnace gas (gas) | 0.02 | ||
| Boiler scale | 1.2 - 3.5 | ||
| Boron | 25 | ||
| Brass | |||
| Breeze block | 0.10 - 0.20 | ||
| Brick dense | 1.31 | ||
| Brick, fire | 0.47 | ||
| Brick, insulating | 0.15 | ||
| Brickwork, common (Building Brick) | 0.6 -1.0 | ||
| Brickwork, dense | 1.6 | ||
| Bromine (gas) | 0.004 | ||
| Bronze | |||
| Brown iron ore | 0.58 | ||
| Butter (15% moisture content) | 0.20 | ||
| Cadmium | |||
| Calcium | 200 | ||
| Calcium silicate | 0.05 | ||
| Carbon | 1.7 | ||
| Carbon disulfide (gas) | 0.0073 | ||
| Carbon dioxide (gas) | 0.0146 | ||
| Carbon monoxide (gas) | 0.0232 | ||
| Cast iron | |||
| Cellulose, cotton, wood pulp and regenerated | 0.23 | ||
Cellulose acetate, molded, sheet |
0.17 - 0.33 | ||
| Cellulose nitrate, celluloid | 0.12 - 0.21 | ||
| Cement, Portland | 0.29 | ||
| Cement, mortar | 1.73 | ||
| Ceramic materials | |||
| Chalk | 0.09 | ||
| Chamotte, fireclay | 1.4 | ||
| Charcoal | 0.084 | ||
| Chlorinated poly-ether | 0.13 | ||
| Chlorine (gas) | 0.0081 | ||
| Chrome Nickel Steel (nickel-chromium steel) | 16.3 | ||
| Chromium | |||
| Chrom-oxide | 0.42 | ||
| City/town gas | 0.064 | ||
| Clay, dry to moist | 0.15 - 1.8 | ||
| Clay, saturated | 0.6 - 2.5 | ||
| Coal | 0.2 | ||
| Cobalt | |||
| Cod (83% moisture content) | 0.54 | ||
| Coke | 0.184 | ||
| Concrete, lightweight | 0.1 - 0.3 | ||
| Concrete, medium | 0.4 - 0.7 | ||
| Concrete, dense | 1.0 - 1.8 | ||
| Concrete, stone | 1.7 | ||
| Constantan | 23.3 | ||
| Copper | |||
| Corian (ceramic filled) | 1.06 | ||
| Cork board | 0.043 | ||
| Cork, re-granulated | 0.044 | ||
| Cork | 0.07 | ||
| Cotton | 0.04 | ||
| Cotton wool | 0.029 | ||
| Carbon Steel | |||
| Cotton Wool insulation | 0.029 | ||
| Cupronickel 30% | 30 | ||
| Diamond | 1000 | ||
| Diatomaceous earth (Sil-o-cel) | 0.06 | ||
| Diatomite | 0.12 | ||
| Duralium | |||
| Earth, dry | 1.5 | ||
| Ebonite | 0.17 | ||
| Emery | 11.6 | ||
| Engine Oil | 0.15 | ||
| Ethane (gas) | 0.018 | ||
| Ethanol vapor | 0.015 | ||
| Ether | 0.14 | ||
| Ethylene (gas) | 0.017 | ||
| Epoxy | 0.35 | ||
| Ethylene glycol | 0.25 | ||
| Feathers | 0.034 | ||
| Felt insulation | 0.04 | ||
| Fiberglass | 0.04 | ||
| Fiber insulating board | 0.048 | ||
| Fiber hardboard | 0.2 | ||
| Fire-clay brick 500 oC | 1.4 | ||
| Fluorine (gas) | 0.0254 | ||
| Foam glass | 0.045 | ||
| Dichlorodifluoromethane R-12 (gas) | 0.007 | ||
| Dichlorodifluoromethane R-12 (liquid) | 0.09 | ||
| Gasoline | 0.15 | ||
| Germanium | 59.9 | ||
| Glass | 1.05 | ||
| Glass, Pearls, dry | 0.18 | ||
| Glass, Pearls, saturated | 0.76 | ||
| Glass, window | 0.96 | ||
| Glass, wool Insulation | 0.04 | ||
| Glycerol | 0.28 | ||
| Gold | |||
| Granite | 1.7 - 4.0 | ||
| Graphite | 168 | ||
| Gravel | 0.7 | ||
| Ground or soil, very moist area | 1.4 | ||
| Ground or soil, moist area | 1.0 | ||
| Ground or soil, dry area | 0.5 | ||
| Ground or soil, very dry area | 0.33 | ||
| Gypsum board | 0.17 | ||
| Hairfelt | 0.05 | ||
| Hardboard high density | 0.15 | ||
| Hardwoods (oak, maple..) | 0.16 | ||
| Hastelloy C | 12 | ||
| Helium (gas) | 0.142 | ||
| Honey (12.6% moisture content) | 0.5 | ||
| Hydrochloric acid (gas) | 0.013 | ||
| Hydrogen (gas) | 0.168 | ||
| Hydrogen chloride (gas) | 0.014 | ||
| Hydrogen sulfide (gas) | 0.013 | ||
| Ice (0 oC, 32 oF) | 2.18 | ||
| Indium | 81.6 | ||
| Inconel | 15 | ||
| Ingot iron | 47 - 58 | ||
| Insulation materials | 0.035 - 0.16 | ||
| Iodine | 0.44 | ||
| Iridium | 147 | ||
| Iron | |||
| Iron-oxide | 0.58 | ||
| Kapok insulation | 0.034 | ||
| Kerosene | 0.15 | ||
| Krypton (gas) | 0.0088 | ||
| Lead | |||
| Leather, dry | 0.14 | ||
| Limestone | 1.26 - 1.33 | ||
| LInoleum | 0.19 | ||
| Lithium | |||
| Magnesia insulation (85%) | 0.07 | ||
| Magnesite | 4.15 | ||
| Magnesium | |||
| Magnesium alloy | 70 - 145 | ||
| Marble | 2.08 - 2.94 | ||
| Mercury, liquid | |||
| Methane (gas) | 0.030 | ||
| Methanol | 0.21 | ||
| Mica | 0.71 | ||
| Milk | 0.53 | ||
| Mineral wool insulation materials, wool blankets .. | 0.04 | ||
| Molybdenum | |||
| Monel | |||
| Neon (gas) | 0.046 | ||
| Neoprene | 0.05 | ||
| Niobium | 53.7 | ||
| Nickel | |||
| Nitric oxide (gas) | 0.0238 | ||
| Nitrogen (gas) | 0.024 | ||
| Nitrous oxide (gas) | 0.0151 | ||
| Nylon 6, Nylon 6/6 | 0.25 | ||
| Oil, machine lubricating SAE 50 | 0.15 | ||
| Olive oil | 0.17 | ||
| Osmium | 87.6 | ||
| Oxygen (gas) | 0.024 | ||
| Ozone (gas) | 0.019 | ||
| Palladium | 70.9 | ||
| Paper | 0.05 | ||
| Paraffin Wax | 0.25 | ||
| Peat | 0.08 | ||
| Perlite, atmospheric pressure | 0.031 | ||
| Perlite, vacuum | 0.00137 | ||
| Phenolic cast resins | 0.15 | ||
| Phenol-formaldehyde moulding compounds | 0.13 - 0.25 | ||
| Phosphorbronze | 110 | ||
| Pinchbeck | 159 | ||
| Pitch | 0.13 | ||
| Pit coal | 0.24 | ||
| Plaster light | 0.2 | ||
| Plaster, metal lath | 0.47 | ||
| Plaster, sand | 0.71 | ||
| Plaster, wood lath | 0.28 | ||
| Plasticine | 0.65 - 0.8 | ||
| Plastics, foamed (insulation materials) | 0.03 | ||
| Platinum | |||
| Plutonium | |||
| Plywood | 0.13 | ||
| Polyamid | 0.31 | ||
| Polycarbonate | 0.19 | ||
| Polyester | 0.05 | ||
| Polyethylene low density, PEL | 0.33 | ||
| Polyethylene high density, PEH | 0.42 - 0.51 | ||
| Polyisoprene natural rubber | 0.13 | ||
| Polyisoprene hard rubber | 0.16 | ||
| Polymethylmethacrylate | 0.17 - 0.25 | ||
| Polypropylene, PP | 0.1 - 0.22 | ||
| Polystyrene, expanded | 0.03 | ||
| Polystyrol | 0.043 | ||
| Polyurethane foam | 0.03 | ||
| Porcelain | 1.5 | ||
| Potassium | 102.4 | ||
| Potato, raw flesh | 0.55 | ||
| Propane (gas) | 0.015 | ||
| Propylene (gas) | 0.017 | ||
| Polytetrafluoroethylene (PTFE) | 0.25 | ||
| Polyvinylchloride, PVC | 0.19 | ||
| Pyrex glass | 1.005 | ||
| Quartz mineral | 3 | ||
| Radium | 18.6 | ||
| Radon (gas) | 0.0033 | ||
| Red metal | |||
| Rhenium | |||
| Rhodium | |||
| Rock, solid | 2 - 7 | ||
| Rock, porous volcanic (Tuff) | 0.5 - 2.5 | ||
| Rock Wool insulation | 0.045 | ||
| Roofing paper | 0.19 | ||
| Rosin | 0.32 | ||
| Rubber, cellular | 0.045 | ||
| Rubber, natural | 0.13 | ||
| Rubidium | |||
| Salmon (73% moisture content) | 0.50 | ||
| Sand, dry | 0.15 - 0.25 | ||
| Sand, moist | 0.25 - 2 | ||
| Sand, saturated | 2 - 4 | ||
| Sandstone | 1.7 | ||
| Sawdust | 0.08 | ||
| Selenium | |||
| Sheep wool | 0.039 | ||
| Silica aerogel | 0.02 | ||
| Silicon cast resin | 0.15 - 0.32 | ||
| Silicon carbide | 120 | ||
| Silicon oil | 0.1 | ||
| Silimanite | 151 | ||
| Silver | |||
| Slag wool | 0.042 | ||
| Slate | 2.01 | ||
| Snow (temp < 0 oC) | 0.05 - 0.25 | ||
| Sodium | |||
| Softwoods (fir, pine ..) | 0.12 | ||
| Soil, clay | 1.1 | ||
| Soil, with organic matter | 0.15 - 2 | ||
| Soil, saturated | 0.6 - 4 | ||
Solder 50-50 |
50 | ||
Soot |
0.07 | ||
Steam, saturated |
0.0184 | ||
| Steam, low pressure | 0.0188 | ||
| Steatite | 2 | ||
| Steel, Carbon | |||
| Steel, Stainless | |||
| Straw slab insulation, compressed | 0.09 | ||
| Styrofoam | 0.033 | ||
| Sulfur dioxide (gas) | 0.0086 | ||
| Sulfur, crystal | 0.2 | ||
| Sulfur hexafluoride | 0.011 | ||
| Sugars | 0.087 - 0.22 | ||
| Tantalum | |||
| Tar | 0.19 | ||
| Tellurium | 4.9 | ||
| Thorium | |||
| Timber, alder | 0.17 | ||
| Timber, ash | 0.16 | ||
| Timber, birch | 0.14 | ||
| Timber, larch | 0.12 | ||
| Timber, maple | 0.16 | ||
| Timber, oak | 0.17 | ||
| Timber, pitchpine | 0.14 | ||
| Timber, pockwood | 0.19 | ||
| Timber, red beech | 0.14 | ||
| Timber, red pine | 0.15 | ||
| Timber, white pine | 0.15 | ||
| Timber, walnut | 0.15 | ||
| Tin | |||
| Titanium | |||
| Tungsten | |||
| Uranium | |||
| Urethane foam | 0.021 | ||
| Vacuum | 0 | ||
| Vanadium | 30.7 | ||
| Vermiculite granules | 0.065 | ||
| Vinyl ester | 0.25 | ||
| Water | 0.606 | ||
| Water, vapor (steam) | 0.0267 | 0.0359 | |
| Wax | 0.084 | ||
| Wheat flour | 0.45 | ||
| White metal | 35 - 70 | ||
| Wood across the grain, white pine | 0.12 | ||
| Wood across the grain, balsa | 0.055 | ||
| Wood across the grain, yellow pine, timber | 0.147 | ||
| Wood, oak | 0.17 | ||
| Wool, felt | 0.07 | ||
| Wood wool, slab | 0.1 - 0.15 | ||
| Xenon (gas) | 0.0051 | ||
| Zinc | |||
| Zirconium | 22.7 | ||
1) Asbestos is bad for human health when the tiny abrasive fibers are inhaled into the lungs where they can damage the lung tissue. This seems to be exacerbated by cigarette smoking and the resulting diseases are mesothelioma and lung cancer.
- 1 W/(m K) = 1 W/(m oC) = 0.85984 kcal/(h m oC) = 0.5779 Btu/(ft h oF) = 0.048 Btu/(in h oF) = 6.935 (Btu in)/(ft² h °F)
- Thermal Conductivity - Unit Converter
- What is conductive heat transfer?
Example - Conductive Heat Transfer through an Aluminum Pot versus a Stainless Steel Pot
The conductive heat transfer through a pot wall can be calculated as
q = (k / s) A dT (1)
or alternatively
q / A = (k / s) dT
q = heat transfer (W, Btu/h)
A = surface area (m2, ft2)
q / A = heat transfer per unit area (W/m2, Btu/(h ft2))
k = thermal conductivity (W/mK, Btu/(hr ft °F))
dT = t1 - t2= temperature difference (oC, oF)
s = wall thickness (m, ft)
Conductive Heat Transfer Calculator
Note! - that the overall heat transfer through a surface is determined by the " overall heat transfer coefficient " - which in addition to conductive heat transfer - depends on
- the convective heat transfer coefficients on the inside and outside of the surfaces
- the radiant heat transfer coefficients on the inside and outside of the surfaces
Conductive Heat Transfer through an Aluminum Pot Wall with thickness 2 mm - temperature difference 80 oC
Thermal conductivity for aluminum is 215 W/(m K) (from the table above). Conductive heat transfer per unit area can be calculated as
q / A = ((215 W/(m K)) / (2×10-3 m)) (80 oC)
= 86 00000 (W/m2)
= 8600 (kW/m2)
Conductive Heat Transfer through a Stainless Steel Pot Wall with thickness 2 mm - temperature difference 80 oC
Thermal conductivity for stainless steel is 17 W/(m K) (from the table above). Conductive heat transfer per unit area can be calculated as
q / A = ((17 W/(m K)) / (2×10-3 m)) (80 oC)
= 680000 (W/m2)
= 680 (kW/m2)
• Insulation
• Thermodynamics
Aluminum Alloys - Mechanical Properties
Mechanical properties of aluminum alloys - tensile strength, yield strength and more.
Brick Densities
Densities of common types of bricks.
Calcium Silicate Insulation
Thermal conductivity of calcium silicate insulation - temperature and k-values.
Carbon Dioxide (CO₂) Properties & Characteristics: Density, Thermal Data & More
Foods - Thermal Conductivities
Thermal conductivity of selected foodstuff like apples, beef, sugar and more.
Typical heat exchanger materials and their thermal conductivities.
Insulation Materials - Operating Temperature Limits
Temperature limits for commonly used insulation materials.
Mineral Wool Insulation
Mortar Types
ASTM mortar types.
Online calculator, figures and tables showing thermal conductivity of nitrogen, N2, at varying temperarure and pressure, SI and Imperial units.
Overall Heat Transfer Coefficient: Definitions, Values & Applications
Pipes and Cylinders - Conductive Heat Loss
Conductive heat losses through cylinder or pipe walls.
Thermal conductivity of plastics.
Thermal Conductivity Units Converter
Thermal Transmittance vs. Thermal Resistance
The thermal transmittance U vs. the thermal resistance R.
