Thermal Conductivity indicates a materials ability to conduct heat.
The calculator below can be used to convert between common units for thermal conductivity:
Thermodynamics
Thermal properties of air at different temperatures - density, viscosity, critical temperature and pressure, triple point, enthalpi and entropi, thermal conductivity and diffusivity and more.
Online calculator, figures and table showing thermal conductivity of carbon dioxide, CO2, at temperatures ranging from -50 to 775 °C (-50 to 1400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Conductive Heat Transfer
Typical heat exchanger materials and their thermal conductivities.
Metals, Metallic Elements and Alloys - Thermal Conductivities
Thermal conductivities of common metals, metallic elements aand alloys.
Overall Heat Transfer Coefficients
Thermal conductivity of plastics.
Thermal conductivity coefficients for insulation materials, aluminum, asphalt, brass, copper, steel, gases and more.
Thermal Conductivity Unit Converter
Unit Factor Method
