Thermal Conductivity - k - is the quantity of heat transmitted due to an unit temperature gradient, in unit time under steady conditions in a direction normal to a surface of the unit area.
Thermal Conductivity - k - is used in the Fourier's equation.
| Metal, Metallic Element or Alloy | Temperature - t - (oC) | Thermal Conductivity - k - (W/m K) |
| Aluminum | -73 | 237 |
| " | 0 | 236 |
| " | 127 | 240 |
| " | 327 | 232 |
| " | 527 | 220 |
| Aluminum - Duralumin (94-96% Al, 3-5% Cu, trace Mg) | 20 | 164 |
| Aluminum - Silumin (87% Al, 13% Si) | 20 | 164 |
| Aluminum bronze | 0 - 25 | 70 |
| Aluminum alloy 3003, rolled | 0 - 25 | 190 |
| Aluminum alloy 2014. annealed | 0 - 25 | 190 |
| Aluminum alloy 360 | 0 - 25 | 150 |
| Antimony | -73 | 30.2 |
| " | 0 | 25.5 |
| " | 127 | 21.2 |
| " | 327 | 18.2 |
| " | 527 | 16.8 |
| Beryllium | -73 | 301 |
| " | 0 | 218 |
| " | 127 | 161 |
| " | 327 | 126 |
| " | 527 | 107 |
| " | 727 | 89 |
| " | 927 | 73 |
| Beryllium copper 25 | 0 - 25 | 80 |
| Bismuth | -73 | 9.7 |
| " | 0 | 8.2 |
| Boron | -73 | 52.5 |
| " | 0 | 31.7 |
| " | 127 | 18.7 |
| " | 327 | 11.3 |
| " | 527 | 8.1 |
| " | 727 | 6.3 |
| " | 927 | 5.2 |
| Cadmium | -73 | 99.3 |
| " | 0 | 97.5 |
| " | 127 | 94.7 |
| Cesium | -73 | 36.8 |
| " | 0 | 36.1 |
| Chromium | -73 | 111 |
| " | 0 | 94.8 |
| " | 127 | 87.3 |
| " | 327 | 80.5 |
| " | 527 | 71.3 |
| " | 727 | 65.3 |
| " | 927 | 62.4 |
| Cobalt | -73 | 122 |
| " | 0 | 104 |
| " | 127 | 84.8 |
| Copper | -73 | 413 |
| " | 0 | 401 |
| " | 127 | 392 |
| " | 327 | 383 |
| " | 527 | 371 |
| " | 727 | 357 |
| " | 927 | 342 |
| Copper, electrolytic (ETP) | 0 - 25 | 390 |
| Copper - Admiralty Brass | 20 | 111 |
| Copper - Aluminum Bronze (95% Cu, 5% Al) | 20 | 83 |
| Copper - Bronze (75% Cu, 25% Sn) | 20 | 26 |
| Copper - Brass (Yellow Brass) (70% Cu, 30% Zn) | 20 | 111 |
| Copper - Cartridge brass (UNS C26000) | 20 | 120 |
| Copper - Constantan (60% Cu, 40% Ni) | 20 | 22.7 |
| Copper - German Silver (62% Cu, 15% Ni, 22% Zn) | 20 | 24.9 |
| Copper - Phosphor bronze (10% Sn, UNS C52400) | 20 | 50 |
| Copper - Red Brass (85% Cu, 9% Sn, 6%Zn) | 20 | 61 |
| Cupronickel | 20 | 29 |
| Germanium | -73 | 96.8 |
| " | 0 | 66.7 |
| " | 127 | 43.2 |
| " | 327 | 27.3 |
| " | 527 | 19.8 |
| " | 727 | 17.4 |
| " | 927 | 17.4 |
| Gold | -73 | 327 |
| " | 0 | 318 |
| " | 127 | 312 |
| " | 327 | 304 |
| " | 527 | 292 |
| " | 727 | 278 |
| " | 927 | 262 |
| Hafnium | -73 | 24.4 |
| " | 0 | 23.3 |
| " | 127 | 22.3 |
| " | 327 | 21.3 |
| " | 527 | 20.8 |
| " | 727 | 20.7 |
| " | 927 | 20.9 |
| Hastelloy C | 0 - 25 | 12 |
| Inconel | 21 - 100 | 15 |
| Incoloy | 0 – 100 | 12 |
| Indium | -73 | 89.7 |
| " | 0 | 83.7 |
| " | 127 | 75.5 |
| Iridium | -73 | 153 |
| " | 0 | 148 |
| " | 127 | 144 |
| " | 327 | 138 |
| " | 527 | 132 |
| " | 727 | 126 |
| " | 927 | 120 |
| Iron | -73 | 94 |
| " | 0 | 83.5 |
| " | 127 | 69.4 |
| " | 327 | 54.7 |
| " | 527 | 43.3 |
| " | 727 | 32.6 |
| " | 927 | 28.2 |
| Iron - Cast | 20 | 52 |
| Iron - Nodular pearlitic | 100 | 31 |
| Iron - Wrought | 20 | 59 |
| Lead | -73 | 36.6 |
| " | 0 | 35.5 |
| " | 127 | 33.8 |
| " | 327 | 31.2 |
| Chemical lead | 0 - 25 | 35 |
| Antimonial lead (hard lead) | 0 - 25 | 30 |
| Lithium | -73 | 88.1 |
| " | 0 | 79.2 |
| " | 127 | 72.1 |
| Magnesium | -73 | 159 |
| " | 0 | 157 |
| " | 127 | 153 |
| " | 327 | 149 |
| " | 527 | 146 |
| Magnesium alloy AZ31B | 0 - 25 | 100 |
| Manganese | -73 | 7.17 |
| " | 0 | 7.68 |
| Mercury | -73 | 28.9 |
| Molybdenum | -73 | 143 |
| " | 0 | 139 |
| " | 127 | 134 |
| " | 327 | 126 |
| " | 527 | 118 |
| " | 727 | 112 |
| " | 927 | 105 |
| Monel | 0 – 100 | 26 |
| Nickel | -73 | 106 |
| " | 0 | 94 |
| " | 127 | 80.1 |
| " | 327 | 65.5 |
| " | 527 | 67.4 |
| " | 727 | 71.8 |
| " | 927 | 76.1 |
| Nickel - Wrought | 0 – 100 | 61 – 90 |
| Cupronickel 50 -45 (Constantan) | 0 - 25 | 20 |
| Niobium (Columbium) | -73 | 52.6 |
| " | 0 | 53.3 |
| " | 127 | 55.2 |
| " | 327 | 58.2 |
| " | 527 | 61.3 |
| " | 727 | 64.4 |
| " | 927 | 67.5 |
| Osmium | 20 | 61 |
| Palladium | 75.5 | |
| Platinum | -73 | 72.4 |
| " | 0 | 71.5 |
| " | 127 | 71.6 |
| " | 327 | 73.0 |
| " | 527 | 75.5 |
| " | 727 | 78.6 |
| " | 927 | 82.6 |
| Plutonium | 20 | 8.0 |
| Potassium | -73 | 104 |
| " | 0 | 104 |
| " | 127 | 52 |
| Rhenium | -73 | 51 |
| " | 0 | 48.6 |
| " | 127 | 46.1 |
| " | 327 | 44.2 |
| " | 527 | 44.1 |
| " | 727 | 44.6 |
| " | 927 | 45.7 |
| Rhodium | -73 | 154 |
| " | 0 | 151 |
| " | 127 | 146 |
| " | 327 | 136 |
| " | 527 | 127 |
| " | 727 | 121 |
| " | 927 | 115 |
| Rubidium | -73 | 58.9 |
| " | 0 | 58.3 |
| Selenium | 20 | 0.52 |
| Silicon | -73 | 264 |
| " | 0 | 168 |
| " | 127 | 98.9 |
| " | 327 | 61.9 |
| " | 527 | 42.2 |
| " | 727 | 31.2 |
| " | 927 | 25.7 |
| Silver | -73 | 403 |
| " | 0 | 428 |
| " | 127 | 420 |
| " | 327 | 405 |
| " | 527 | 389 |
| " | 727 | 374 |
| " | 927 | 358 |
| Sodium | -73 | 138 |
| " | 0 | 135 |
| Solder 50 - 50 | 0 - 25 | 50 |
| Steel - Carbon, 0.5% C | 20 | 54 |
| Steel - Carbon, 1% C | 20 | 43 |
| Steel - Carbon, 1.5% C | 20 | 36 |
| " | 400 | 36 |
| " | 122 | 33 |
| Steel - Chrome, 1% Cr | 20 | 61 |
| Steel - Chrome, 5% Cr | 20 | 40 |
| Steel - Chrome, 10% Cr | 20 | 31 |
| Steel - Chrome Nickel, 15% Cr, 10% Ni | 20 | 19 |
| Steel - Chrome Nickel, 20% Cr, 15% Ni | 20 | 15.1 |
| Steel - Hastelloy B | 20 | 10 |
| Steel - Hastelloy C | 21 | 8.7 |
| Steel - Nickel, 10% Ni | 20 | 26 |
| Steel - Nickel, 20% Ni | 20 | 19 |
| Steel - Nickel, 40% Ni | 20 | 10 |
| Steel - Nickel, 60% Ni | 20 | 19 |
| Steel - Nickel Chrome, 80% Ni, 15% Cr | 20 | 17 |
| Steel - Nickel Chrome, 40% Ni, 15% Cr | 20 | 11.6 |
| Steel - Manganese, 1% Mn | 20 | 50 |
| Steel - Stainless, Type 304 | 20 | 14.4 |
| Steel - Stainless, Type 347 | 20 | 14.3 |
| Steel - Tungsten, 1% W | 20 | 66 |
| Steel - Wrought Carbon | 0 | 59 |
| Tantalum | -73 | 57.5 |
| " | 0 | 57.4 |
| " | 127 | 57.8 |
| " | 327 | 58.9 |
| " | 527 | 59.4 |
| " | 727 | 60.2 |
| " | 927 | 61 |
| Thorium | 20 | 42 |
| Tin | -73 | 73.3 |
| " | 0 | 68.2 |
| " | 127 | 62.2 |
| Titanium | -73 | 24.5 |
| " | 0 | 22.4 |
| " | 127 | 20.4 |
| " | 327 | 19.4 |
| " | 527 | 19.7 |
| " | 727 | 20.7 |
| " | 927 | 22 |
| Tungsten | -73 | 197 |
| " | 0 | 182 |
| " | 127 | 162 |
| " | 327 | 139 |
| " | 527 | 128 |
| " | 727 | 121 |
| " | 927 | 115 |
| Uranium | -73 | 25.1 |
| " | 0 | 27 |
| " | 127 | 29.6 |
| " | 327 | 34 |
| " | 527 | 38.8 |
| " | 727 | 43.9 |
| " | 927 | 49 |
| Vanadium | -73 | 31.5 |
| " | 0 | 31.3 |
| " | 427 | 32.1 |
| " | 327 | 34.2 |
| " | 527 | 36.3 |
| " | 727 | 38.6 |
| " | 927 | 41.2 |
| Zinc | -73 | 123 |
| " | 0 | 122 |
| " | 127 | 116 |
| " | 327 | 105 |
| Zirconium | -73 | 25.2 |
| " | 0 | 23.2 |
| " | 127 | 21.6 |
| " | 327 | 20.7 |
| " | 527 | 21.6 |
| " | 727 | 23.7 |
| " | 927 | 25.7 |
Alloys - Temperature and Thermal Conductivity
Temperature and thermal conductivity for
- Hastelloy A
- Inconel
- Nichrome V
- Kovar
- Advance
- Monel
alloys:
Aluminum - Thermophysical Properties
Density, specific heat and thermal conductivity related to temperature.
Aluminum Alloys - Mechanical Properties
Mechanical properties of aluminum alloys - tensile strength, yield strength and more.
Chromium - Specific Heat and Thermal Conductivities vs. Temperatures
Specific heat and thermal conductivity of chromium related to temperature.
Conductive Heat Transfer
Foods - Thermal Conductivities
Thermal conductivity of selected foodstuff like apples, beef, sugar and more.
Typical heat exchanger materials and their thermal conductivities.
Iron - Density, Specific Heats and Thermal Conductivities vs. Temperatures
Specific heat, density and thermal conductivity of iron related to temperature.
Metal Alloys - Specific Heats
Specific heat of metal alloys like brass, bronze and more.
Metals - Boiling Points and Specific Heat
Boiling points and specific heat of liquid metals.
Metals - Boiling Temperatures
Metals and their boiling temperatures.
Metals - Latent Heat of Melting
Metals and their latent heat of fusion.
Metals - Specific Heats
Metals and Alloys - Densities
Metals Strength vs. Temperature
The influence of temperature on the strength of metals.
Online calculator, figures and tables showing thermal conductivity of nitrogen, N2, at varying temperarure and pressure, SI and Imperial units.
Thermal conductivity of plastics.
Poisson's Ratios Metals
Stainless Steel - Specific Heat and Thermal Conductivities vs. Temperatures
Specific heat and thermal conductivity of stainless steel vs. temperature
Thermal Conductivity of Common Materials - Solids, Liquids and Gases
Thermal conductivity of various common materials, including metals, gases, and building materials. Essential data for engineers, architects, and designers working with heat transfer and insulation.
Thermal Conductivity Units Converter
