(K)
The four basic types of cast iron - white iron, gray iron, ductile iron and malleable iron.
Dimensions of cast iron soil pipes.
Metals and their latent heat of fusion.
The influence of temperature on the strength of metals.
Thermal conductivities of common metals, metallic elements aand alloys.
