It is convenient to express the elasticity of a material with the ratio stress to strain, a parameter also termed as the tensile elastic modulus or Young's modulus of the material - usually with the symbol - E.
  • Young's modulus can be used to predict the elongation or compression of an object.
Modulus of Elasticity for some common metals at various temperatures according ASME B31.1-1995:
  • 1 psi (lb/in2) = 1 psi (lb/in2) = 144 psf (lbf/ft2) = 6,894.8 Pa (N/m2) = 6.895x10-3 N/mm2
  • T(oC) = 5/9[T(oF) - 32]
For full table with Higher Temperatures - rotate the screen!
MetalYoung's Modulus of Elasticity - E - (106 psi)
Temperature (oC)
-200-129-732193149204260316371427482538593649
Temperature (oF)
-325-200-10070200300400500600700800900100011001200
Cast iron
Gray cast iron 13.4 13.2 12.9 12.6 12.2 11.7 11.0 10.2
Steel
Carbon steel C <= 0.3% 31.4 30.8 30.2 29.5 28.8 28.3 27.7 27.3 26.7 25.5 24.2 22.4 20.4 18.0
Carbon steel C => 0.3% 31.2 30.6 30.0 29.3 28.6 28.1 27.5 27.1 26.5 25.3 24.0 22.2 20.2 17.9 15.4
Carbon-molybdenum steels 31.1 30.5 29.9 29.2 28.5 28.0 27.4 27.0 26.4 25.3 23.9 22.2 20.1 17.8 15.3
Nickel steels Ni 2% - 9% 29.6 29.1 28.5 27.8 27.1 26.7 26.1 25.7 25.2 24.6 23.0
Cr-Mo steels Cr 1/2% - 2% 31.6 31.0 30.4 29.7 29.0 28.5 27.9 27.5 26.9 26.3 25.5 24.8 23.9 23.0 21.8
Cr-Mo steels Cr 2 1/4% - 3% 32.6 32.0 31.4 30.6 29.8 29.4 28.8 28.3 27.7 27.1 26.3 25.6 24.6 23.7 22.5
Cr-Mo steels Cr 5% - 9% 32.9 32.3 31.7 30.9 30.1 29.7 29.0 28.6 28.0 27.3 26.1 24.7 22.7 20.4 18.2
Chromium steels Cr 12%, 17%, 27% 31.2 30.7 30.1 29.2 28.5 27.9 27.3 26.7 26.1 25.6 24.7 23.2 21.5 19.1 16.6
Austenitic steels (TP304, 310, 316, 321, 347) 30.3 29.7 29.1 28.3 27.6 27.0 26.5 25.8 25.3 24.8 24.1 23.5 22.8 22.1 21.2
Copper and copper alloys
Comp. and leaded-Sn bronze (C83600, C92200) 14.8 14.6 14.4 14.0 13.7 13.4 13.2 12.9 12.5 12.0
Naval brass Si & Al bronze (C46400, C65500, C95200, C95400) 15.9 15.6 15.4 15.0 14.6 14.4 14.1 13.8 13.4 12.8
Copper (C11000) 16.9 16.6 16.5 16.0 15.6 15.4 15.0 14.7 14.2 13.7
Copper red brass Al-bronze (C10200, C12000, C12200, C12500, C14200,  C23000,  C61400) 18.0 17.7 17.5 17.0 16.6 16.3 16.0 15.6 15.1 14.5
Nickel and Nickel Alloys
Monel 400 (N04400) 27.8 27.3 26.8 26.0 25.4 25.0 24.7 24.3 24.1 23.7 23.1 22.6 22.1 21.7 21.2
Titanium
Unalloyed titanium grades 1, 2, 3 and 7 15.5 15.0 14.6 14.0 13.3 12.6 11.9 11.2
Aluminum and aluminum alloys
Grades 443, 1060, 1100, 3003, 3004, 6063 11.1 10.8 10.5 10.0 9.6 9.2 8.7
  • 1 psi (lb/in2) = 6,894.8 N/m2 (Pa)
Note! You can use the pressure unit converter to switch between units of Modulus of Elasticity.
Material Properties
ASME/ANSI B36.10/19 - Carbon, Alloy and Stainless Steel Pipes - Dimensions
Copper, Zinc and Tin Alloys
Strength of Copper, Zinc and Tin alloys.
Hooke's Law
Hooke's law - force, elongation and spring constant.
Iron - Density, Specific Heats and Thermal Conductivities vs. Temperatures
Specific heat, density and thermal conductivity of iron related to temperature.
Metal Alloys - Specific Heats
Specific heat of metal alloys like brass, bronze and more.
Metals - Strength vs. Temperature
The influence of temperature on the strength of metals.
The Bulk Modulus - resistance to uniform compression - for some common metals and alloys.
Modulus of Rigidity
Poisson's Ratio
When a material is stretched in one direction it tends to get thinner in the other two directions.
Stiffness
Stiffness is resistance to deflection.
Superheated Steam - Entropy
The entropy of steam superheated to temperatures above saturation points.
Young's Modulus, Tensile Strength and Yield Strength Values for some Materials
Young's Modulus (or Tensile Modulus alt. Modulus of Elasticity) and Ultimate Tensile Strength and Yield Strength for materials like steel, glass, wood and many more.
