Elongation
Bolt stretching according Hook's Law can be calculated as
dl = F L / E A (1)
dl = change in length of bolt (inches, m)
F = applied tensile load (lb, N)
L = effective length of bolt where tensile strength is applied (inches, m)
E = Young's Modulus of Elasticity (psi, N/m2)
A = tensile stress area of the bolt (square inches, m2)
Stress Area
The tensile stress area can be calculated as
A = (π / 4) (d - 0.9743 / n)2 (2)
d = nominal diameter of bolt (in)
n = 1 / p = number of threads per inch
p = pitch, length per thread (in)
Tensile Stress
Tensile stress can be calculated as
σ = F / A (3)
σ = tensile stress (psi, N/m2 (Pa))
Example - Bolt Stretching - Imperial Units
- stud diameter : 7/8 inches
- thread pitch : 9
- Young's Modulus steel : 30 106 psi
- designed bolt load : 10000 lb
- effective length : 5 inches
A = 0.7854 ((7/8 in) - 0.9743 / 9)2
= 0.46 (in2)
The elongation can be calculated as
dl = (10000 lb) (5 in) / ((30 106 psi) (0.46 in2))
= 0.0036 (inches)
The tensile stress can be calculated as
σ = (10000 lb) / (0.46 in2)
= 21740 psi
• Fasteners
ASME/ANSI B16 Standards for Pipes and Fittings
The ASME B16 standards covers pipes and fittings in cast iron , cast bronze, wrought copper and steel.
Bolt Torque Calculator
Calculate required bolt torque.
Cast Iron Flanges - Stud Reference Chart
The number, diameter and length of studs for cast iron flanges class 125 and 250.
Hooke's Law
Hooke's law - force, elongation and spring constant.
ISO 724 - Metric Threads
Metric Bolt Heads and Wrench Sizes
ANSI/SO, DIN and JIS bolts.
Metric Bolts - Minimum Ultimate Tensile and Proof Loads
Modulus of Rigidity
Pipe Class Ratings vs. Pressure Numbers (PN)
Pipe Flanges and Gaskets - Dimensions
Gasket dimensions according ASME B16.5 Pipe Flanges and Flange Fittings.
Reduced Torque with Lubricated Bolts
Steel Bolts - ASTM Grades
Steel Bolts - SAE Grades
Threaded Bolts - Stress Area
Threaded bolts tensile stress area.
UNC and UNF - Unified Inch Screw Threads
US Bolts - Tensile Strength and Proof Loads
US Hex Bolts - Inches
ANSI/ASME B18.2.1 Dimensions of Hex Bolts - Imperial units.
US Hex Bolts - Metric
Wrench Spanners - Inches vs. mm
Convert between US Inches and metric mm wrench and spanner sizes.
Young's Modulus, Tensile Strength and Yield Strength Values for some Materials
Young's Modulus (or Tensile Modulus alt. Modulus of Elasticity) and Ultimate Tensile Strength and Yield Strength for materials like steel, glass, wood and many more.
