ASME/ANSI B16.1 Cast Iron Pipe Flanges and Flanged Fittings - Class 125 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
API and ASME/ANSI flanges - comparing dimensions and pressure ratings.
Diameters and bolt circles for standard ASME B16.5 flanges - 1/4 to 24 inches - Class 150 to 2500.
Number of studs, diameter and length for ANSI forged steel flanges ranging class 150 to 1500.
Japanese industrial flanges, bolts, nuts, and gaskets standards and specifications from JAS - the Japanese Standards Association.
ANSI/SO, DIN and JIS bolts.
Threaded bolts tensile stress area.
Hex Bolt, Lag Bolt, Square Bolt and Heavy Hex Bolt.
Recommended bolt torques.
Torque specifications Whitworth bolts.
