Unified Thread Standards: UNC & UNF Size Charts & Specifications
- UNC – Unified National Coarse Thread - comparable with the ISO metric thread
- UNF – Unified National Fine Thread
- Female and Male UNC/UNF threads are both parallel
- The UNC/UNF flank angle is 60°
Unified threads comes in three different classes:
- for applications where a liberal tolerance is required to permit easy assembly even with slightly nicked threads
- most commonly used class for general applications
- for applications where closeness of fit and/or accuracy of thread elements are important
UNC - Unified Coarse Threads
UNC threads according ANSI B1.1:
| Major Diameter (in) | Threads per inch (tpi) | Major Diameter | Tap Drill Size (mm) | Pitch (mm) | |
| (in) | (mm) | ||||
| #1 - 64 | 64 | 0.073 | 1.854 | 1.50 | 0.397 |
| #2 - 56 | 56 | 0.086 | 2.184 | 1.80 | 0.453 |
| #3 - 48 | 48 | 0.099 | 2.515 | 2.10 | 0.529 |
| #4 - 40 | 40 | 0.112 | 2.845 | 2.35 | 0.635 |
| #5 - 40 | 40 | 0.125 | 3.175 | 2.65 | 0.635 |
| #6 - 32 | 32 | 0.138 | 3.505 | 2.85 | 0.794 |
| #8 - 32 | 32 | 0.164 | 4.166 | 3.50 | 0.794 |
| #10 - 24 | 24 | 0.190 | 4.826 | 4.00 | 1.058 |
| #12 - 24 | 24 | 0.216 | 5.486 | 4.65 | 1.058 |
| 1/4" - 20 | 20 | 0.250 | 6.350 | 5.35 | 1.270 |
| 5/16" - 18 | 18 | 0.313 | 7.938 | 6.80 | 1.411 |
| 3/8" - 16 | 16 | 0.375 | 9.525 | 8.25 | 1.587 |
| 7/16" - 14 | 14 | 0.438 | 11.112 | 9.65 | 1.814 |
| 1/2" - 13 | 13 | 0.500 | 12.700 | 11.15 | 1.954 |
| 9/16" - 12 | 12 | 0.563 | 14.288 | 12.60 | 2.117 |
| 5/8" - 11 | 11 | 0.625 | 15.875 | 14.05 | 2.309 |
| 3/4" - 10 | 10 | 0.750 | 19.050 | 17.00 | 2.540 |
| 7/8" - 9 | 9 | 0.875 | 22.225 | 20.00 | 2.822 |
| 1" - 8 | 8 | 1.000 | 25.400 | 22.85 | 3.175 |
| 1 1/8" - 7 | 7 | 1.125 | 28.575 | 25.65 | 3.628 |
| 1 1/4" - 7 | 7 | 1.250 | 31.750 | 28.85 | 3.628 |
| 1 3/8" - 6 | 6 | 1.375 | 34.925 | 31.55 | 4.233 |
| 1 1/2" - 6 | 6 | 1.500 | 38.100 | 34.70 | 4.233 |
| 1 3/4" - 5 | 5 | 1.750 | 44.450 | 40.40 | 5.080 |
| 2" - 4 1/2 | 4 1/2 | 2.000 | 50.800 | 46.30 | 5.644 |
| 2 1/4" - 4 1/2 | 4 1/2 | 2.250 | 57.150 | 52.65 | 5.644 |
| 2 1/2" - 4 | 4 | 2.500 | 63.500 | 58.50 | 6.350 |
| 2 3/4" - 4 | 4 | 2.750 | 69.850 | 64.75 | 6.350 |
| 3" - 4 | 4 | 3.000 | 76.200 | 71.10 | 6.350 |
| 3 1/4" - 4 | 4 | 3.250 | 82.550 | 77.45 | 6.350 |
| 3 1/2" - 4 | 4 | 3.500 | 88.900 | 83.80 | 6.350 |
| 3 3/4" - 4 | 4 | 3.750 | 95.250 | 90.15 | 6.350 |
| 4" - 4 | 4 | 4.000 | 101.600 | 96.50 | 6.350 |
Pitch is the distance between screw grooves and is commonly used with inch sized products and specified as threads per inch. Lead is the linear travel the nut makes per one screw revolution. The pitch and lead are equal.
Example - Typical designation of an UNC thread
- 1/4” x 20 UNC
UNF - Unified National Fine Threads
UNF threads ANSI B1.1:
| (in) | (mm) | ||||
| #0 - 80 | 80 | 0.060 | 1.524 | 1.25 | 0.317 |
| #1 - 72 | 72 | 0.073 | 1.854 | 1.55 | 0.353 |
| #2 - 64 | 64 | 0.086 | 2.184 | 1.90 | 0.397 |
| #3 - 56 | 56 | 0.099 | 2.515 | 2.15 | 0.453 |
| #4 - 48 | 48 | 0.112 | 2.845 | 2.40 | 0.529 |
| #5 - 44 | 44 | 0.125 | 3.175 | 2.70 | 0.577 |
| #6 - 40 | 40 | 0.138 | 3.505 | 2.95 | 0.635 |
| #8 - 36 | 36 | 0.164 | 4.166 | 3.50 | 0.705 |
| #10 - 32 | 32 | 0.190 | 4.826 | 4.10 | 0.794 |
| #12 - 28 | 28 | 0.216 | 5.486 | 4.70 | 0.907 |
| 1/4" - 28 | 28 | 0.250 | 6.350 | 5.50 | 0.907 |
| 5/16" - 24 | 24 | 0.313 | 7.938 | 6.90 | 1.058 |
| 3/8" - 24 | 24 | 0.375 | 9.525 | 8.50 | 1.058 |
| 7/16" - 20 | 20 | 0.438 | 11.112 | 9.90 | 1.270 |
| 1/2" - 20 | 20 | 0.500 | 12.700 | 11.50 | 1.270 |
| 9/16" - 18 | 18 | 0.563 | 14.288 | 12.90 | 1.411 |
| 5/8" - 18 | 18 | 0.625 | 15.875 | 14.50 | 1.411 |
| 3/4" - 16 | 16 | 0.750 | 19.050 | 17.50 | 1.587 |
| 7/8" - 14 | 14 | 0.875 | 22.225 | 20.40 | 1.814 |
| 1" - 12 | 12 | 1.000 | 25.400 | 23.25 | 2.117 |
| 1 1/8" - 12 | 12 | 1.125 | 28.575 | 26.50 | 2.117 |
| 1 1/4" - 12 | 12 | 1.250 | 31.750 | 29.50 | 2.117 |
| 1 3/8" - 12 | 12 | 1.375 | 34.925 | 32.75 | 2.117 |
| 1 1/2" - 12 | 12 | 1.500 | 38.100 | 36.00 | 2.117 |
Example - Typical designation of an UNF thread
- 1/2” x 20 UNF
• Fasteners
• Mechanics
• Threads
Thread data - metric, unified, ACME and others.
ANSI/ASME B1.5 - ACME Screw Threads
Acme trapezoidal threads.
ASME/ANSI B16.5 Flanges and Bolt Dimensions - Class 150 to 2500
Diameters and bolt circles for standard ASME B16.5 flanges - 1/4 to 24 inches - Class 150 to 2500.
BS 21 - Pressure Tight Pipe Thread Joints
BSPT - British Standard Pipe Taper threads & BSP or BSPF - British Standard Pipe Parallel (Straight) threads.
Cast Iron Flanges - Stud Reference Chart
The number, diameter and length of studs for cast iron flanges class 125 and 250.
EN 10226 - Pipe Threads where pressure tight joints are made on the threads - Dimensions
Pipe threads where pressure tight joints are made on the threads - Part 1: Taper external threads and parallel internal threads.
ISO 28741 Metric Thread Dimensions for Spark Plugs
Metric threads spark plugs according ISO 28741.
ISO 2901 - Metric Trapezoidal Screw Threads
Dimensions of ISO metric trapezoidal screw threads.
ISO 7 - Pipe Threads where Pressure-tight Joints are made on the Threads
Pressure-tight joints made on the pipe threads.
ISO 724 - Metric Threads
Lumber - Surface Finishing
Lumber and surface finishing abbreviations.
Metric Bolt Heads and Wrench Sizes
ANSI/SO, DIN and JIS bolts.
Screws - Metric vs. Inches
Metric versus Imperial equivalent screw dimensions.
Steel Bolts - ASTM Grades
Steel Bolts - SAE Grades
Threaded Bolts - Stress Area
Threaded bolts tensile stress area.
U.S. Bolts - Head and Wrench Sizes
Hex Bolt, Lag Bolt, Square Bolt and Heavy Hex Bolt.
U.S. Bolts - Tightening Torques
Recommended bolt torques.
US Hex Bolts - Inches
ANSI/ASME B18.2.1 Dimensions of Hex Bolts - Imperial units.
US Hex Bolts - Metric
US Machine Screws - Dimensions
Machine screw diameters.
US Wood Screws - Nominal Sizes
Wood screws - nominal sizes vs. diameters.
Whitworth Pipe Threads
BSPP (G) - British Standard Pipe Parallel and BSPT (R/Rp) – British Standard Tapered Pipe for pipes and tapered threads - G/R/Rp.
Wood Screws - Withdrawal Force
Allowable withdrawal load force.
Wrench Size Conversion Chart – Metric (mm) to SAE (Inches)
Convert between metric and SAE (inch) wrench sizes with this comprehensive comparison chart. Find the closest equivalent sizes for your tools, whether working with US standard (SAE) or metric fasteners.
