US Machine Screws - Dimensions
| Size no. | Thread Diameter | TPI | ||
| Decimal (in) | Nearest Fractional (in) | Fine | Coarse | |
| 0 | 0.0600 | 1/16 | 80 | |
| 1 | 0.0730 | 5/64 | 72 | 64 |
| 2 | 0.0860 | 3/32 | 64 | 56 |
| 3 | 0.0990 | 7/64 | 56 | 48 |
| 4 | 0.1120 | 7/64 | 48 | 40 |
| 5 | 0.1250 | 1/8 | 44 | 40 |
| 6 | 0.1380 | 9/64 | 40 | 32 |
| 8 | 0.1640 | 5/32 | 36 | 32 |
| 10 | 0.1900 | 3/16 | 32 | 24 |
| 12 | 0.2160 | 7/32 | 28 | 24 |
| 1/4 | 0.2500 | 1/4 | 28 | 20 |
| 5/16 | 0.3125 | 5/16 | 24 | 18 |
| 3/8 | 0.3750 | 3/8 | 24 | 16 |
- TPI = threads per inch
- threads according UNF – Unified National Fine Thread
• Fasteners
Metric Bolt Heads and Wrench Sizes
ANSI/SO, DIN and JIS bolts.
Screws - Metric vs. Inches
Metric versus Imperial equivalent screw dimensions.
U.S. Bolts - Head and Wrench Sizes
Hex Bolt, Lag Bolt, Square Bolt and Heavy Hex Bolt.
U.S. Bolts - Tightening Torques
Recommended bolt torques.
Unified Thread Standards: UNC & UNF Size Charts & Specifications
Machine screw diameters.
US Wood Screws - Nominal Sizes
Wood screws - nominal sizes vs. diameters.
US Wood Screws - Pilot Holes
Hard wood and soft wood pilot holes, shank clearance holes and countersink diameters.
Wood Screws - Withdrawal Force
Allowable withdrawal load force.
Wrench Size Conversion Chart – Metric (mm) to SAE (Inches)
Convert between metric and SAE (inch) wrench sizes with this comprehensive comparison chart. Find the closest equivalent sizes for your tools, whether working with US standard (SAE) or metric fasteners.
