US Wood Screws - Nominal Sizes
Wood screws shank diameters and recommended pilot holes are indicated below.
Shank holes and pilot holes is recommended to prevent wood from splitting and allows tighter joints.
| Nominal Size no. | Shank Diameter | |
| Decimal (in) | Nearest Fractional (in) | |
| 0 | 0.060 | 1/16 |
| 1 | 0.073 | 5/64 |
| 2 | 0.086 | 3/32 |
| 3 | 0.099 | 7/64 |
| 4 | 0.112 | 7/64 |
| 5 | 0.125 | 1/8 |
| 6 | 0.138 | 9/64 |
| 7 | 0.151 | 5/32 |
| 8 | 0.164 | 5/32 |
| 9 | 0.177 | 11/64 |
| 10 | 0.190 | 3/16 |
| 11 | 0.203 | 13/64 |
| 12 | 0.216 | 7/32 |
| 14 | 0.242 | 1/4 |
| 16 | 0.268 | 17/64 |
| 18 | 0.294 | 19/64 |
| 20 | 0.320 | 5/16 |
• Fasteners
Drill Bits - Conversion Chart
Convert between drill bit dimensions - gauge numbers, inches and mm.
Hardwood and Softwoods - Recommended Drill Bit Speeds
Hardwood and softwood drill speed chart.
Hardwood Lumber - Dimensions
Sizing of hardwood lumber.
ISO 724 - Metric Threads
Nails and Spikes - Withdrawal Force
Allowable withdrawal load for nail and spikes.
Screws - Metric vs. Inches
Metric versus Imperial equivalent screw dimensions.
Unified Thread Standards: UNC & UNF Size Charts & Specifications
US Machine Screws - Dimensions
Machine screw diameters.
US Wood Screws - Pilot Holes
Hard wood and soft wood pilot holes, shank clearance holes and countersink diameters.
Wood Headers - Max. Supported Weight
Wood Screws - Withdrawal Force
Allowable withdrawal load force.
