Wood Headers - Max. Supported Weight
Use The Engineering ToolBox Sketchup Extension to insert construction lumber in your 3D models.
Weight supported by a double or triple wood header on two 4" x 4" posts:
Span (feet) | MAx. Weight (lb) | |||||
2 x 2" x 6" | 3 x 2" x 6" | 2 x 2" x 8" | 3 x 2" x 8" | 2 x 2"×10" | 3 x 2"×10" | |
4 | 2250 | 3780 | 4690 | 5850 | 5000 | 7410 |
6 | 1680 | 2520 | 3130 | 4690 | 5000 | 7410 |
8 | 2660 | 3990 | 3760 | 5640 | ||
10 | 2130 | 3190 | 3010 | 4510 | ||
12 | 2510 | 3760 | ||||
- 1 inch = 25.4 mm
- 1 lbf = 0.45 kgf = 4.45 N
- Mass and Weight - the difference
• Beams and Columns
Board Feet Chart and Calculator
Board feet is used as a volume measurement of lumber.
Cantilever Beam Calculations: Formulas, Loads & Deflections
Density of Wood Species: Data & Material Guide
Floor Joist Capacities
Floors - Live Loads
Glue-Laminated Timber - Dimensions
Common sizing of glue-laminated timber.
Hardwood Lumber - Dimensions
Sizing of hardwood lumber.
Horizontal Roof Rafters - Maximum Spans
Douglas Fir in horizontal roof rafters and maximum spans.
Lumber Weights: Green, Kiln-Dried & Pressure-Treated Wood
Machine Stress Rated (MSR) and Machine Evaluated (MEL) Lumber
Grading of lumber in North America
Maximum Floor Joist Span
No. 1 and No. 2 Grade of Douglas fir and maximum span floor joists - imperial units
Nails and Spikes - Withdrawal Force
Allowable withdrawal load for nail and spikes.
Softwood and Hardwood - Structural Strength Classes
Strength classes, bending stress and mean density of hardwood and softwood
Softwood Lumber - Dimensions
Commercial softwood lumber dimension chart - nominal and actual sizes.
Trusses
Common types of trusses.
US Wood Screws - Nominal Sizes
Wood screws - nominal sizes vs. diameters.
US Wood Screws - Pilot Holes
Hard wood and soft wood pilot holes, shank clearance holes and countersink diameters.
Wood - Compressive Strength vs. Moisture Content
Red Spruce, Longleaf Pine and Douglas Fir - moisture content and their compressive strength.
Wood Beams - Strength of Material
Wood Columns - Safe Loads
Safe loads for wood columns.
Wood Hardness
Soft and hardwood - the Janka Hardness scale.
Wood Screws - Withdrawal Force
Allowable withdrawal load force.
Wood, Panel and Structural Timber Products - Mechanical Properties
Density, fibre stress, compressive strength and modulus of elasticity of clear wood, panel and structural timber products.
