Board feet is used as a volume measurement of lumber.
Wood screws, machine screws, sheet metal screws, self drilling SMS and more.
Sizing of hardwood lumber.
Lumber and surface finishing abbreviations.
Commercial softwood lumber dimension chart - nominal and actual sizes.
Rough lumber, surfaced lumber (dressed), worked lumber, shop and factory lumber and yard lumber.
Basic size, area, moments of inertia and section modulus for timber - metric units.
The density of wood versus moisture content.
Safe loads for wood columns.
Allowable withdrawal load force.
