Structural Lumber - Section Sizes
Size | Area | Section Modulus | Area Moment of Inertia | Radius of Gyration | |||
Sxx | Syy | Ixx | Iyy | rxx | ryy | ||
(mm x mm) | (102 mm2) | (103 mm3) | (103 mm3) | (106 mm4) | (106 mm4) | (mm) | (mm) |
100 x 38 | 38 | 63.3 | 24.1 | 3.17 | 0.46 | 28.9 | 11.0 |
100 x 50 | 50 | 83.3 | 41.7 | 4.17 | 1.04 | 28.9 | 14.4 |
100 x 63 | 63 | 105 | 66.2 | 5.25 | 2.08 | 28.9 | 18.2 |
100 x 75 | 75 | 125 | 93.8 | 6.25 | 3.52 | 28.9 | 21.7 |
100×100 | 100 | 167 | 167 | 8.33 | 8.33 | 28.9 | 28.9 |
150 x 38 | 57 | 143 | 36.1 | 10.7 | 0.69 | 43.3 | 11.0 |
150 x 50 | 75 | 188 | 62.5 | 14.1 | 1.56 | 43.3 | 14.4 |
150 x 63 | 94 | 236 | 99.2 | 17.7 | 3.13 | 43.3 | 18.2 |
150 x 75 | 112 | 281 | 141 | 21.1 | 5.27 | 43.3 | 21.7 |
150×100 | 150 | 375 | 250 | 28.1 | 12.5 | 43.3 | 28.9 |
150 x 150 | 225 | 563 | 563 | 42.2 | 42.2 | 43.3 | 43.3 |
175 x 38 | 66 | 194 | 42.1 | 17.0 | 0.80 | 50.5 | 11.0 |
175 x 50 | 87 | 255 | 72.9 | 22.3 | 1.82 | 50.5 | 14.4 |
175 x 63 | 110 | 322 | 116 | 28.1 | 3.65 | 50.5 | 18.2 |
175 x 75 | 131 | 383 | 164 | 33.5 | 6.15 | 50.5 | 21.7 |
200 x 38 | 76 | 253 | 48.1 | 25.3 | 0.91 | 57.7 | 11.0 |
200 x 50 | 100 | 333 | 83.3 | 33.3 | 2.08 | 57.7 | 14.4 |
200 x 63 | 126 | 420 | 132 | 42.0 | 4.17 | 57.7 | 18.2 |
200 x 75 | 150 | 500 | 188 | 50.0 | 7.03 | 57.7 | 21.7 |
200×100 | 200 | 667 | 333 | 66.7 | 16.7 | 57.7 | 28.9 |
200 x 150 | 300 | 1000 | 750 | 100 | 56.3 | 57.7 | 43.3 |
200 x 200 | 400 | 1333 | 1333 | 133 | 133 | 57.7 | 57.7 |
225 x 38 | 85 | 321 | 54.2 | 36.1 | 1.03 | 65.0 | 11.0 |
225 x 50 | 112 | 422 | 93.8 | 47.5 | 2.34 | 65.0 | 14.4 |
225 x 63 | 141 | 532 | 149 | 59.8 | 4.69 | 65.0 | 18.2 |
225 x 75 | 168 | 633 | 211 | 71.2 | 7.91 | 65.0 | 21.7 |
250 x 50 | 125 | 521 | 104 | 65.1 | 2.60 | 72.2 | 14.4 |
250 x 75 | 187 | 781 | 234 | 97.7 | 8.79 | 72.2 | 21.7 |
250×100 | 250 | 1042 | 417 | 130 | 20.8 | 72.2 | 28.9 |
250 x 250 | 625 | 2604 | 2604 | 326 | 326 | 72.2 | 72.2 |
• Beams and Columns
Area Moment of Inertia Converter
Convert between Area Moment of Inertia units.
Area Moment of Inertia with Definitions, Formulas & Calculator
Explore the area moment of inertia (second moment of area) with detailed formulas, calculation tools, and reference tables for common shapes. Essential for structural and mechanical engineering applications.
Board Feet Chart and Calculator
Board feet is used as a volume measurement of lumber.
Density of Wood Species: Data & Material Guide
Glue-Laminated Timber - Dimensions
Common sizing of glue-laminated timber.
Hardwood and Softwood Species
Species of hardwood vs. softwood.
Hardwood Lumber - Dimensions
Sizing of hardwood lumber.
Horizontal Roof Rafters - Maximum Spans
Douglas Fir in horizontal roof rafters and maximum spans.
Lumber Weights: Green, Kiln-Dried & Pressure-Treated Wood
Mass Moment of Inertia
The Mass Moment of Inertia vs. mass of object, it's shape and relative point of rotation - the Radius of Gyration.
Maximum Floor Joist Span
No. 1 and No. 2 Grade of Douglas fir and maximum span floor joists - imperial units
Radius of Gyration in Structural Engineering
Radius of gyration describes the distribution of cross sectional area in columns around their centroidal axis.
Softwood and Hardwood - Structural Strength Classes
Strength classes, bending stress and mean density of hardwood and softwood
Softwood Lumber - Dimensions
Commercial softwood lumber dimension chart - nominal and actual sizes.
Softwood Lumber - Grading
Rough lumber, surfaced lumber (dressed), worked lumber, shop and factory lumber and yard lumber.
Structural Lumber - Properties
Wood Beams - Strength of Material
Wood Hardness
Soft and hardwood - the Janka Hardness scale.
Wood, Panel and Structural Timber Products - Mechanical Properties
Density, fibre stress, compressive strength and modulus of elasticity of clear wood, panel and structural timber products.
