Section Modulus - Unit Converter
The Elastic Section Modulus of a beam is the ratio of the cross section Area Moment of Inertia to its greatest distance from the neutral axis.
For a simple solid Square the Section Modulus can be expressed as
Sx = Sy
= a3/ 6 (1)
S = Elastic Section Modulus - related to bending around x vs. y axis (m3, cm3, ft3, in3)
a = square side distance (m, in, ft..)
Converter
| Convert from | Multiply with | |||
| Convert to | ||||
| m3 | cm3 | ft3 | in3 | |
| m3 | 1 | 106 | 35.31466 | 61,023.76 |
| cm3 | 10-6 | 1 | 3.5×10-5 | 6.1×10-2 |
| ft3 | 0.02831685 | 28373 | 1 | 1728 |
| in3 | 0.00001638706 | 16.38 | 5.78×10-4 | 1 |
Example - Convert Section Modulus in unit in3 to cm3
12 in3 can be converted to cm3 by multiplying with 16.38 - as
(12 in3) (16.38 cm3/in3) = 196.6 cm3
• Beams and Columns
• Mechanics
American Wide Flange Steel Beams: Dimensions and Properties (ASTM A6 in Metric)
Area Moment of Inertia Converter
Convert between Area Moment of Inertia units.
Area Moment of Inertia with Definitions, Formulas & Calculator
Explore the area moment of inertia (second moment of area) with detailed formulas, calculation tools, and reference tables for common shapes. Essential for structural and mechanical engineering applications.
Beams Fixed at Both Ends with Continuous and Point Loads: Load & Deflection Formulas
Center of Gravity
A body and the center of gravity.
Modulus of Rigidity
Pipe and Tubing Formulas
Pipe and Tube Equations - moment of inertia, section modulus, traverse metal area, external pipe surface and traverse internal area - imperial units
Unit Factor Method
