R A = F (3 a + b) b 2 / L 3 (1f)
R A = support force at fixed end A (N, lb f )
R B = F (a + 3 b) a 2 / L 3 (1g)
R B = support force at fixed end B (N, lb f )
M A = M B
= - q L 2 / 12 (2a)
M = moments at the fixed ends (Nm, lb f ft)
q = uniform load (N/m, lb f /ft)
M 1 = q L 2 / 24 (2b)
M 1 = moment at the center (Nm, lb f ft)
δ max = q L 4 / (384 E I) (2c)
δ max = max deflection at center (m, ft)
E = Modulus of Elasticity (Pa (N/m 2 ), N/mm 2 , psi)
I = Area Moment of Inertia (m 4 , mm 4 , in 4 )
R A = R B
= q L / 2 (2d)
R = support forces at the fixed ends (N, lb f )
M A = - q L 2 / 20 (3a)
M A = moments at the fixed end A (Nm, lb f ft)
q = uniform declining load (N/m, lb f /ft)
M B = - q L 2 / 30 (3b)
M B = moments at the fixed end B (Nm, lb f ft)
M 1 = q L 2 / 46.6 (3c)
M 1 = moment at x = 0.475 L (Nm, lb f ft)
δ max = q L 4 / (764 E I) (3d)
δ max = max deflection at x = 0.475 L (m, ft)
δ 1/2 = q L 4 / (768 E I) (3e)
δ 1/2 = deflection at x = 0.5 L (m, ft)
R A = 7 q L / 20 (3f)
R A = support force at the fixed end A (N, lb f )
R B = 3 q L / 20 (3g)
R B = support force at the fixed end B (N, lb f )
M A = - (q a 2 / 6) (3 - 4 a / l + 1.5 (a / L) 2 ) (4a)
M A = moment at the fixed end A (Nm, lb f ft)
q = partly uniform load (N/m, lb f /ft)
M B = - (q a 2 / 3) (a / L - 0.75 (a / L) 2 ) (4b)
M B = moment at the fixed end B (Nm, lb f ft)
R A = q a (L - 0.5 a) / L - (M A - M B ) / L (4c)
R B = q a 2 / (2 L) + (M A - M B ) / L (4d)
Dimensions and static properties of aluminum I-beams - Imperial units.
Area Moment of Inertia, Moment of Inertia for an Area or Second Moment of Area for typical cross section profiles.
Convert between Area Moment of Inertia units.
Estimate structures natural vibration frequency.
Moments and reaction support forces with distributed or point loads.
Calculate the acting forces and moments when elevating drawbridges or beams.
Properties of HE-M profile steel beams.
Convert between Elastic Section Modulus units.
Stiffness is resistance to deflection.
Support reactions and bending moments.
Common types of trusses.
Uniformly and concentrated floor loads
Allowable uniform loads.
Stress and deformation of vertical beams due to own weight.
