Area Moment of Inertia - Typical Cross Sections II
Area Moment of Inertia or Moment of Inertia for an Area - also known as Second Moment of Area - I, is a property of shape that is used to predict deflection, bending and stress in beams.
Area Moment of Inertia for typical Cross Sections II
Angle with Equal Legs
The Area Moment of Inertia for an angle with equal legs can be calculated as
Ix = 1/3 [2c4 - 2 (c - t)4 + t (h - 2 c + 1/2 t)3]                       (1a)
c = yt cos 45o                             (1b)
and
yt = (h2 + ht + t2) / [2 (2 h - t ) cos 45o]                               (1c)
Angle with Unequal Legs
The Area Moment of Inertia for an angle with unequal legs can be calculated as
Ix = 1/3 [t (h - yd)3 + b yd3 - b1 (yd - t)3]                            (2a)
Iy = 1/3 [t (b - xd)3 + h xd3 - h1 (xd - t)3]                            (2b)
xd = (b2 + h1 t) / (2 (b + h1))                                 (2c)
yd = (h2 + b1 t) / (2 (h + b1))
Triangle
The Area Moment of Inertia for a triangle can be calculated as
Ix =  b h3 / 36                                (3a)
Iy = h b (b2 - ba bc) / 36                         (3b)
Rectangular Triangle
The Area Moment of Inertia for a rectangular triangle can be calculated as
Ix =  b h3 / 36                                (4a)
Iy =h b3 / 36                              (4b)
Beams and Columns
Mechanics
American Standard Beams - S Beam
American Standard Steel C Channels
American Wide Flange Beams
Area Moment of Inertia Converter
Convert between Area Moment of Inertia units.
Beams - Fixed at Both Ends - Continuous and Point Loads
Beams - Supported at Both Ends - Continuous and Point Loads
Center Mass
Calculate position of center mass.
Euler's Column Formula
Calculate buckling of columns.
HE-A Steel Beams
HE-B Steel Beams
HE-M Steel Beams
Properties of HE-M profile steel beams.
Mass Moment of Inertia
The Mass Moment of Inertia vs. mass of object, it's shape and relative point of rotation - the Radius of Gyration.
Normal Flange I-Beams
Steel Angles - Equal Legs
Steel Angles - Unequal Legs
W-Beams - American Wide Flange Beams
