Mass Moment of Inertia
Mass Moment of Inertia (Moment of Inertia) - I - is a measure of an object's resistance to change in rotation direction. Moment of Inertia has the same relationship to angular acceleration as mass has to linear acceleration.
- Moment of Inertia of a body depends on the distribution of mass in the body with respect to the axis of rotation
For a point mass the Moment of Inertia is the mass times the square of perpendicular distance to the rotation reference axis and can be expressed as
I = m r2 (1)
I = moment of inertia ( kg m2, slug ft2, lbf fts2)
m = mass (kg, slugs)
r = distance between axis and rotation mass (m, ft)
Example - Moment of Inertia of a Single Mass
make 3D models with the free Engineering ToolBox Sketchup Extension
The Moment of Inertia with respect to rotation around the z-axis of a single mass of 1 kg distributed as a thin ring as indicated in the figure above, can be calculated as
Iz = (1 kg) ((1000 mm) (0.001 m/mm))2
= 1 kg m2
Moment of Inertia - Distributed Masses
Point mass is the basis for all other moments of inertia since any object can be "built up" from a collection of point masses.
I = ∑i (mi ri2)
= m1 r12 + m2 r22 + ..... + mn rn2 (2)
For rigid bodies with continuous distribution of adjacent particles the formula is better expressed as an integral
I = ∫ r2 dm (2b)
dm = mass of an infinitesimally small part of the body
Convert between Units for the Moment of Inertia
| Multiply with | ||||||
| from | to | |||||
| kg m2 | g cm2 | lbm ft2 | lbm in2 | slug ft2 | slug in2 | |
| kg m2 | 1 | 1×107 | 2.37×101 | 3.42×103 | 7.38×10-1 | 1.06×102 |
| g cm2 | 1×10-7 | 1 | 2.37×10-6 | 3.42×10-4 | 7.38×10-8 | 1.06×105 |
| lbm ft2 | 4.21×10-2 | 4.21×105 | 1 | 1.44×102 | 3.11×10-2 | 4.48 |
| lbm in2 | 2.93×10-4 | 2.93×103 | 6.94×10-3 | 1 | 2.16×10-4 | 3.11×10-2 |
| slug ft2 | 1.36 | 1.36×107 | 3.22×101 | 4.63×103 | 1 | 1.44×102 |
| slug in2 | 9.42×10-3 | 9.42×104 | 2.23×10-1 | 3.22×101 | 6.94×10-3 | 1 |
Moment of Inertia - General Formula
A generic expression of the inertia equation is
I = k m r2 (2c)
k = inertial constant - depending on the shape of the body
Radius of Gyration (in Mechanics)
The Radius of Gyration is the distance from the rotation axis where a concentrated point mass equals the Moment of Inertia of the actual body. The Radius of Gyration for a body can be expressed as
rg = (I / m)1/2 (2d)
rg = radius of gyration (m, ft)
I = moment of inertia for the body (kg m2, slug ft2)
m = mass of the body (kg, slugs)
Some Typical Bodies and their Moments of Inertia
Cylinder
Thin-walled hollow cylinder
Moments of Inertia for a thin-walled hollow cylinder is comparable with the point mass (1) and can be expressed as:
I = m r2 (3a)
m = mass of the hollow (kg, slugs)
r = distance between axis and the thin walled hollow (m, ft)
ro = distance between axis and outside hollow (m, ft)
Hollow cylinder
I = 1/2 m (ri 2+ ro 2) (3b)
m = mass of hollow (kg, slugs)
ri = distance between axis and inside hollow (m, ft)
Solid cylinder
I = 1/2 m r2 (3c)
m = mass of cylinder (kg, slugs)
r = distance between axis and outside cylinder (m, ft)
Circular Disk
I = 1/2 m r2 (3d)
m = mass of disk (kg, slugs)
r = distance between axis and outside disk (m, ft)
Sphere
Thin-walled hollow sphere
I = 2/3 m r2 (4a)
m = mass of sphere hollow (kg, slugs)
r = distance between axis and hollow (m, ft)
Solid sphere
I = 2/5 m r2 (4b)
m = mass of sphere (kg, slugs)
r = radius in sphere (m, ft)
Rectangular Plane
Moments of Inertia for a rectangular plane with axis through center can be expressed as
I = 1/12 m (a2+ b2) (5)
a, b = short and long sides
Moments of Inertia for a rectangular plane with axis along edge can be expressed as
I = 1/3 m a2 (5b)
Slender Rod
Moments of Inertia for a slender rod with axis through center can be expressed as
I = 1/12 m L2 (6)
L = length of rod
Moments of Inertia for a slender rod with axis through end can be expressed as
I = 1/3 m L2 (6b)
• Basics
• Dynamics
• Mechanics
• Statics
American Wide Flange Steel Beams: Dimensions and Properties (ASTM A6 in Metric)
Area Moment of Inertia - Typical Cross Sections II
Area Moment of Inertia, Moment of Inertia for an Area or Second Moment of Area for typical cross section profiles.
Area Moment of Inertia Converter
Convert between Area Moment of Inertia units.
Area Moment of Inertia with Definitions, Formulas & Calculator
Explore the area moment of inertia (second moment of area) with detailed formulas, calculation tools, and reference tables for common shapes. Essential for structural and mechanical engineering applications.
Cantilever Beam Calculations: Formulas, Loads & Deflections
Center Mass
Calculate position of center mass.
Conn-Rod Mechanism
The connecting rod mechanism.
Euler Column Buckling: Formula, Theory & Calculator
Calculate buckling of columns.
Flywheels - Kinetic Energy
The kinetic energy stored in flywheels - the moment of inertia.
Mass vs. Weight
Pipe and Tubing Formulas
Pipe and Tube Equations - moment of inertia, section modulus, traverse metal area, external pipe surface and traverse internal area - imperial units
Radius of Gyration in Structural Engineering
Radius of gyration describes the distribution of cross sectional area in columns around their centroidal axis.
Rotating Shafts - Torque
Torsional moments acting on rotating shafts.
Shafts Torsion
The torsion of solid or hollow shafts - Polar Moment of Inertia of Area.
Structural Lumber - Section Sizes
Basic size, area, moments of inertia and section modulus for timber - metric units.
Support Reactions - Equilibrium
Static equilibrium is achieved when the resultant force and resultant moment equals to zero.
Three-Hinged Arches - Continuous and Point Loads
Support reactions and bending moments.
Torque - Work done and Power Transmitted
The work done and power transmitted by a constant torque.
