Conn-Rod Mechanism
A connecting rod - conn-rod - mechanism converts rotating motion to reciprocating motion - or vice versa.
The position of the rod can be expressed as
s = r (1 - cos φ) + (λ / 2) r sin2φ (1)
s = position of the rod (m)
r = radius of crank (m)
φ = ω t
= 2 π ns t
= angular position of crank (rad)
ω = crank angular velocity (rad/s)
t = time (s)
ns = revolution per second (1/s)
λ = r / l
= crank ratio
l = length of rod (m)
The velocity of the rod can be expressed as
v = ω r sin φ (1 + λ cos φ) (2)
v = velocity of rod (m/s)
The acceleration of the rod can be expressed as
a = ω2 r (cos φ + λ cos 2φ) (3)
a = acceleration of rod (m/s2)
• Mechanics
Acceleration
Change in velocity vs. time used.
Angular Motion - Power and Torque
Angular velocity and acceleration vs. power and torque.
Centripetal and Centrifugal Acceleration Force
Forces due to circular motion and centripetal / centrifugal acceleration.
Flywheels - Kinetic Energy
The kinetic energy stored in flywheels - the moment of inertia.
Gear Reducing Formulas
Output torque, speed and horsepower with gears.
Gears
Gears effort force vs. load force.
Mass Moment of Inertia
The Mass Moment of Inertia vs. mass of object, it's shape and relative point of rotation - the Radius of Gyration.
Movement Ratio
Machines and movement ratio (velocity ratio).
Torque - Work done and Power Transmitted
The work done and power transmitted by a constant torque.
