Belts (or chains) are used to transfer power (or convert torque) through rotational motion from one shaft to an other. Belt driven fans are common in heating, ventilation, air-conditioning and cooling (HVAC) systems. Chain are common in many transmission systems like bicycles and other.
  • friction belts - transfer the power through friction between the pulley and the belt
  • synchronous belts - transfer the power through a mechanical linkage between the teeth in the belt and the grooves in the pulley
Belt Length
The length of the belt can be calculated as
lb = (dm π / 2) + (df π / 2) + (2 lfm) + ((df - dm)2 / (4 lfm))                                (1)
lb = length of belt (mm, inches)
df = pulley (sheave) diameter fan (mm, inches)
dm = pulley (sheave) diameter motor (mm, inches)
π = 3.14..
lfm = center to center distance of fan and motor pulleys (mm, inches)
Belt Velocity
The velocity at which a belt travels may be expressed as
v = π dm nm / 12                                    (2)
v = velocity of belt (ft/min)
nm = revolutions motor (rpm)
- or alternatively in metric units:
vb = π dm nm / 60                         (2b)
vb = velocity of belt (m/s)
dmb = diameter motor pulley  (m)
Belt Transmissions - Belt Speed
Pitch Diameter of Pulley
(in)
Velocity (ft/min)
Revolutions Pulley - n -(rpm)
850105010751140155017253450
1 223 275 281 298 406 452 903
2 445 550 563 597 812 903 1806
3 668 825 844 895 1217 1355 2710
4 890 1100 1126 1194 1623 1806 3613
5 1113 1374 1407 1492 2029 2258 4516
6 1335 1649 1689 1791 2435 2710 5419
7 1558 1924 1970 2089 2841 3161 6322
8 1780 2199 2251 2388 3246 3613 7226
9 2003 2474 2533 2686 3652 4064 8129
10 2225 2749 2814 2985 4058 4516 9032
Belt Gearing
The relationship between the rotational speed of the motor and the fan and the disc diameter can be expressed as
df nf = dm nm                               (3)
or
nf = nm dm / df
Belt Gearing Calculator
Horsepower
If belt tension and belt velocity are known - horsepower transferred can be calculated as
Php = Fb vb / 33000                                (4)
Php = power (hp)
Fb = belt tension (lbf)
vb = velocity of belt (ft/min)
If torque and revolution per minute are known - horsepower transferred can be calculated as
Php = T n / 5252                                  (4)
Php = power (hp)
T = torque (ft lbf)
n = revolutions per minute (rpm)
Speed Ratio
Speed ratio can be calculated as
SR = nf / ns                            (5)
SR = speed ratio
nf = revolutions per minute - fastest machine
ns = revolutions per minute - slowest machine
Mechanics
Ventilation Systems
Belt driven Fans - Fan vs. Motor Speed
Fan vs. motor speed in belt driven fans.
Belts - Power Transmission and Efficiency
Calculate belts power transmission and efficiency
Belts - Pulley Diameters vs. Speed
The pulley laws - driver and driven - diameter and rpm
Conn-Rod Mechanism
The connecting rod mechanism.
Conveyors - Belt Speed
Maximum conveyor belt speed.
Conveyors - Capacities
Calculate conveyor capacities.
Conveyors - Load & Power Consumption
Conveyor required power consumption vs. load.
Conveyors - Maximum Inclination vs. Product
Maximum conveyor inclination slopes for typical products.
Efficiency of Small Machine Elements
Friction and efficiency in bearings and roller chains.
Electrical Motors - Service Factors
Service factor - SF - is a measure of periodically overload capacity at which a motor can operate without beeing damaged.
Fan Affinity Laws
The affinity laws can be used to calculate resulting volume capacity, head or power consumption when speed or wheel diameters are changed.
Flywheels - Kinetic Energy
The kinetic energy stored in flywheels - the moment of inertia.
Gear Reducing Formulas
Output torque, speed and horsepower with gears.
Gear Trains - Bicycle Gearing Calculator
Gear train transmissions - bicycle gearing.
Gears
Gears effort force vs. load force.
Motors - Speed vs. Pulley Diameter
Pulley (Sheave) selection charts for motors ranging 850 - 3450 rpm.
Pulleys
Pulleys, blocks and tackles.
Torque - Work done and Power Transmitted
The work done and power transmitted by a constant torque.
