Belts - Power Transmission and Efficiency
The torque available at the driven wheel or pulley (a) can be expressed as
T = (F2 - F1) ra (1)
T = torque (Nm)
F = force (N)
r = radius of wheel or pulley
The available power can be expressed as
P = T ωa = (F2 - F1) ra ωa (2)
P = power transmitted (watts)
ωa = angular velocity (rad/s)
• Mechanics
Calculate belts power transmission and efficiency
Belts - Pulley Diameters vs. Speed
The pulley laws - driver and driven - diameter and rpm
Conveyors - Belt Speed
Maximum conveyor belt speed.
Conveyors - Capacities
Calculate conveyor capacities.
Conveyors - Load & Power Consumption
Conveyor required power consumption vs. load.
Conveyors - Maximum Inclination vs. Product
Maximum conveyor inclination slopes for typical products.
Efficiency of Small Machine Elements
Friction and efficiency in bearings and roller chains.
Electrical Motors - Service Factors
Service factor - SF - is a measure of periodically overload capacity at which a motor can operate without beeing damaged.
Gear Trains - Bicycle Gearing Calculator
Gear train transmissions - bicycle gearing.
Motors - Speed vs. Pulley Diameter
Pulley (Sheave) selection charts for motors ranging 850 - 3450 rpm.
Pulleys
Pulleys, blocks and tackles.
Torque - Work done and Power Transmitted
The work done and power transmitted by a constant torque.
