Torque - Work done and Power Transmitted
Work done
Work done is the force multiplied with the distance moved by the force - and can be expressed as
W = F s                                  (1)
W = work done (J, Nm)
F = force (N)
s = distance moved by force (s)
For an angular motion
the work done can be expressed as
W = F θ r
   = T θ                                     (2)
W = work (Joules)
θ = angle (radians)
r = radius (m)
T = torque or moment (Nm)
Power transmitted
Power is the ratio between the work done and the time taken and can be expressed as
 P = W / dt
    = T θ / dt
    = T ω
    = 2 π n T
    = 2 π (nrpm / 60) T
    = 0.105 nrpm T                                  (3)
P = power (Watts)
dt = time taken (s)
ω =  θ / dt
= 2 π n
= angular velocity (rad/s)
n = speed (rev/s)
nrpm = speed (rev/min, rpm)
Note! - a machine must rotate to produce power! A machine with no rotation can deliver torque - like an electric motor - but since no distance is moved by force - no power is produced. As soon as the machine starts to rotate power is produced.
Example - required Torque to produce Power
A machine rotates with speed 3000 rev/min (rpm) and consumes 5 kW. The torque at the shaft can be calculated by modifying (3) to
T = P / 2 π n
    = (5 kW) (1000 W/kW) / 2 π (3000 rev/min) / (60 sec/min)
    = 15.9 Nm
Mechanics
Belts - Power Transmission and Efficiency
Calculate belts power transmission and efficiency
Conn-Rod Mechanism
The connecting rod mechanism.
Distance Traveled vs. Speed and Time - Calculator and Chart
Velocity plotted in time used diagram.
Electric Motors - IEC and NEMA Standard Torques
IEC and NEMA torque classifications of electrical motors.
Electrical Induction Motors - Torque vs. Speed
Full load operating torque vs. break down, pull up and locked rotor torque.
Elevators - Force and Power
Required force and power to lift an elevator.
Improvised Torque Wrench
Mass Moment of Inertia
The Mass Moment of Inertia vs. mass of object, it's shape and relative point of rotation - the Radius of Gyration.
Power
Rotating Shafts - Torque
Torsional moments acting on rotating shafts.
Shafts Torsion
The torsion of solid or hollow shafts - Polar Moment of Inertia of Area.
Work done by Force
Work done by a force acting on an object.
