Rotating Shafts - Torque
A torsional moment or torque acting on a rotating shaft can be expressed as
T = Php 33000 12 / (2 π w)
   = 63057 Php / n                            (1)
T = torque - or moment (lb in)
Php= horsepower (hp)
n = revolution per minute (rpm)
  • 1 hp (English horse power) = 745.7 W
  • 1 lb in = 0.113 Nm
Example - Car Engine Torque vs. Power and RPM
A car combustion engine deliveres 100 hp at 5000 rpm to the shaft. The torque in the shaft can be calculated as
T = 63057 (100 hp) / (5000 rpm)
   = 12611 lb in
   = 143 Nm
Torque vs. Power and Revolutions Calculator
Mechanics
Flywheels - Kinetic Energy
The kinetic energy stored in flywheels - the moment of inertia.
Mass Moment of Inertia
The Mass Moment of Inertia vs. mass of object, it's shape and relative point of rotation - the Radius of Gyration.
Modulus of Rigidity
Shafts Torsion
The torsion of solid or hollow shafts - Polar Moment of Inertia of Area.
Stress in Thin-Walled Cylinders or Tubes
Hoop and longitudinal stress thin-walled tubes or cylinders.
Torque - Work done and Power Transmitted
The work done and power transmitted by a constant torque.
