Flywheels - Kinetic Energy
A flywheel can be used to smooth energy fluctuations and make the energy flow intermittent operating machine more uniform. Flywheels are used in most combustion piston engines.
Energy is stored mechanically in a flywheel as kinetic energy.
Kinetic Energy
Kinetic energy in a flywheel can be expressed as
Ef = 1/2 I ω2                              (1)
Ef = flywheel kinetic energy (Nm, Joule, ft lb)
I = moment of inertia (kg m2, lb ft2)
ω = angular velocity ( rad /s)
Angular Velocity - Convert Units
  • 1 rad = 360o/ 2 π =~ 57.29578o
  • 1 rad/s = 9.55 rev/min (rpm) = 0.159 rev/s (rps)
Moment of Inertia
Moment of inertia quantifies the rotational inertia of a rigid body and can be expressed as
I = k m r2                              (2)
k = inertial constant - depends on the shape of the flywheel
m = mass of flywheel (kg, lbm)
r = radius (m, ft)
Inertial constants of some common types of flywheels
  • wheel loaded at rim like a bicycle tire - k =1
  • flat solid disk of uniform thickness - k = 0.606
  • flat disk with center hole - k = ~0.3
  • solid sphere - k = 2/5
  • thin rim - k = 0.5
  • radial rod - k = 1/3
  • circular brush - k = 1/3
  • thin-walled hollow sphere - k = 2/3
  • thin rectangular rod - k = 1/2
Moment of Inertia - Convert Units
  • 1 kg m2= 10000 kg cm2= 54675 ounce in2= 3417.2 lb in2= 23.73 lb ft2
Flywheel Rotor Materials
MaterialDensity
(kg/m3)
Design Stress
(MPa)
Specific Energy
(kWh/kg)
Aluminum alloy 2700
Birch plywood 700 30
Composite carbon fiber - 40% epoxy 1550 750 0.052
E-glass fiber - 40% epoxy 1900 250 0.014
Kevlar fiber - 40% epoxy 1400 1000 0.076
Maraging steel 8000 900 0.024
Titanium Alloy 4500 650 0.031
"Super paper" 1100
S-glass fiber/epoxy 1900 350 0.020
  • 1 MPa = 106 Pa = 106 N/m2= 145 psi
  • Maraging steels are carbon free iron-nickel alloys with additions of cobalt, molybdenum, titanium and aluminum. The term maraging is derived from the strengthening mechanism, which is transforming the alloy to martensite with subsequent age hardening.
Example - Energy in a Rotating Bicycle Wheel
A typical 26-inch bicycle wheel rim has a diameter of 559 mm (22.0") and an outside tire diameter of about 26.2" (665 mm) . For our calculation we approximate the radius - r - of the wheel to
r = ((665 mm) + (559 mm) / 2) / 2
=  306 mm
= 0.306 m
The weight of the wheel with the tire is 2.3 kg and the inertial constant is k = 1 .
The Moment of Inertia for the wheel can be calculated
I = (1) (2.3 kg) (0.306 m)2
= 0.22 kg m2
The speed of the bicycle is 25 km/h ( 6.94 m/s) . The wheel circular velocity (rps, revolutions/s) - nrps - can be calculated as
nrps = (6.94 m/s) / (2 π (0.665 m) / 2)
= 3.32 revolutions/s
The angular velocity of the wheel can be calculated as
ω = (3.32 revolutions/s) (2 π rad/revolution)
= 20.9 rad/s
The kinetic energy of the rotating bicycle wheel can then be calculated to
Ef = 0.5 (0.22 kg m2) (20.9 rad/s)2
= 47.9 J
Dynamics
Mechanics
Angular Motion - Power and Torque
Angular velocity and acceleration vs. power and torque.
Conn-Rod Mechanism
The connecting rod mechanism.
Energy
Energy is the capacity to do work.
Energy Storage Density
Energy density - by weight and volume - for some ways to store energy
Impulse and Impulse Force
Forces acting a very short time are called impulse forces.
Kinetic Energy
Energy possessed by an object's motion is kinetic energy.
Mass Moment of Inertia
The Mass Moment of Inertia vs. mass of object, it's shape and relative point of rotation - the Radius of Gyration.
Rotating Bodies - Stress
Stress in rotating disc and ring bodies.
Rotating Shafts - Torque
Torsional moments acting on rotating shafts.
Salt Hydrates - Melting points and Latent Melting Energy
Melting points and latent energy of salt hydrates.
