Potential power and energy stored in capacitors.
The kinetic energy stored in flywheels - the moment of inertia.
Power potential vs. head and flow rate.
Energy stored in a magnetic field.
Energy possessed by an object's motion is kinetic energy.
Specific gravity and charge of lead acid batteries - temperature and efficiency.
Weight and strength of sandstone, granite, limestone, marble and slate.
Energy stored as sensible heat in materials.
The most common units of heat BTU - British Thermal Unit, Calorie and Joule.
