Specific Heat of Common Materials – Engineering Reference
Specific Heat for some common products are given in the table below.
See also tabulated values for gases, food and foodstuff, metals and semimetals, common liquids and fluids and common solids, as well as values of molar specific heat for common organic substances and inorganic substances.
| Substance | Specific Heat - cp - (J/kg C°) |
| Acetals | 1460 |
| Air, dry (sea level) | 1005 |
| Agate | 800 |
| Alcohol, ethyl | 2440 |
| Alcohol, metyl wood) | 2530 |
| Aluminum | 897 |
| Aluminum bronze | 436 |
| Alumina, AL2O3 | 718 |
| Ammonia, liquid | 4700 |
| Ammonia, gas | 2060 |
| Antimony | 209 |
| Argon | 520 |
| Arsenic | 348 |
| Artificial wool | 1357 |
| Asbestos | 816 |
| Asphalt concrete (with aggregate) | 920 |
| Barium | 290 |
| Barium chloride | 380 |
| Barytes | 460 |
| Basalt | 860 |
| Beef tallow | 870 |
| Beryllium | 1020 |
| Bismuth | 130 |
| Bitumen | 1780 |
| Boiler scale | 800 |
| Bone | 440 |
| Borax | 1000 |
| Boron | 960 |
| Boron nitride | 720 |
| Brass | 375 |
| Brick | 840 |
| Bronze | 370 |
| Brown iron ore | 670 |
| Cadmium | 234 |
| Calcium | 532 |
| Calcium chloride | 690 |
| Calsium silicate, CaSiO3 | 710 |
| Cellulose, cotton, wood pulp and regenerated | 1300 - 1500 |
| Cellulose acetate, molded | 1260 - 1800 |
| Cellulose acetate, sheet | 1260 - 2100 |
| Cellulose nitrate, Celluloid | 1300 - 1700 |
| Chalk | 750 |
| Chamotte, fireclay | 800 |
| Charcoal | 840 |
| Chromium | 452 |
| Chromium oxide | 750 |
| Clay, sandy | 1381 |
| Clay, dry | 880 |
| Cobalt | 435 |
| Coke | 840 |
| Concrete | 880 |
| Constantan | 410 |
| Copper | 385 |
| Cork | 2000 |
| Diamond (carbon) | 516 |
| Duralium | 920 |
| Emery | 960 |
| Epoxy cast resins | 1000 |
| Fire brick | 880 |
| Fluorspar CaF2 | 830 |
| Dichlorodifluoromethane R12, liquid | 871 |
| Dichlorodifluoromethane R12, vapor | 595 |
| Ice (0 oC) | 2093 |
| India rubber | 1250 |
| Germanium | 310 |
| Glass, crown | 670 |
| Glass, pyrex | 753 |
| Glass-wool | 840 |
| Gold | 129 |
| Granite | 790 |
| Graphite (carbon) | 717 |
| Gypsum | 1090 |
| Helium | 5193 |
| Hydrogen | 14304 |
| Ice, snow (-5 oC) | 2090 |
| Indium | 240 |
| Ingot iron | 490 |
| Iodine | 218 |
| Iridium | 134 |
| Iron | 449 |
| Lead | 129 |
| Leather | 1500 |
| Limestone | 909 |
| Lithium | 3582 |
| Lucite | 1460 |
| Magnesia (Mangnesium oxide), MgO | 874 |
| Magnesium | 1050 |
| Magnesium alloy | 1010 |
| Manganese | 460 |
| Marble | 880 |
| Mercury | 140 |
| Mica | 880 |
| Molybdenum | 272 |
| Monel metal | 430 |
| Neon | 1030 |
| Nickel | 461 |
| Nitrogen | 1040 |
| Nobium | 260 |
| Nylon-6 | 1600 |
| Nylon-66 | 1700 |
| Olive oil | 1790 |
| Osmium | 130 |
| Oxygen | 918 |
| Palladium | 240 |
| Paper | 1336 |
| Paraffin | 3260 |
| Peat | 1900 |
| Perlite | 387 |
| Phenolic cast resins | 1250 - 1670 |
| Phenol-formaldehyde molding compounds | 2500 - 6000 |
| Phosphorbonze | 360 |
| Phosphorus | 800 |
| Pinchbeck | 380 |
| Pit coal | 1020 |
| Plaster | 1090 |
| Platinium | 133 |
| Plutonium | 140 |
| Polycarbonate | 1170 - 1250 |
| Polyethylene terephthalate | 1250 |
| Polyimide aromatics | 1120 |
| Polyisoprene natural rubber | 1880 |
| Polyisoprene hard rubber | 1380 |
| Polymethylmethacrylate | 1500 |
Polypropylene |
1920 |
| Polystyrene | 1300 - 1500 |
| Polytetrafluoroethylene moulding compound | 1000 |
| Polytetrafluoroethylene (PTFE) | 1172 |
| Polyurethane cast liquid | 1800 |
| Polyurethane elastomer | 1800 |
| Polyvinylchloride PVC | 840 - 1170 |
| Porcelain | 1085 |
| Potassium | 1000 |
| Potassium chloride | 680 |
| Pyroceram | 710 |
| Quartz, SiO2 | 730 |
| Quartz glass | 700 |
| Radium | 120 |
| Red metal | 381 |
| Rhenium | 140 |
| Rhodium | 240 |
| Rosin | 1300 |
| Rubidium | 330 |
| Salt, NaCl | 880 |
| Sand, quartz | 830 |
| Sandstone | 710 |
| Scandium | 568 |
| Selenium | 330 |
| Silicon | 705 |
| Silicon carbide | 670 |
| Sillimanite | 1000 |
| Silver | 235 |
| Slate | 760 |
| Sodium | 1260 |
| Soil, dry | 800 |
| Soil, wet | 1480 |
| Soot | 840 |
| Snow | 2090 |
| Steatite | 830 |
| Steel | 490 |
| Sulfur, crystal | 700 |
| Tantalium | 138 |
| Tellurium | 201 |
| Thorium | 140 |
| Timber, alder | 1400 |
| Timber, ash | 1600 |
| Timber, birch | 1900 |
| Timber, larch | 1400 |
| Timber, maple | 1600 |
| Timber, oak | 2400 |
| Timber, pitchpine | 1300 |
| Timber, pockwood | 2500 |
| Timber, red beech | 1300 |
| Timber, red pine | 1500 |
| Timber, white pine | 1500 |
| Timber, walnut | 1400 |
| Tin | 228 |
| Titanium | 523 |
| Tungsten | 132 |
| Tungsten carbide | 171 |
| Uranium | 116 |
| Vanadium | 500 |
| Water, pure liquid (20 oC) | 4182 |
| Water, vapor (27 oC) | 1864 |
| Wax | 3400 |
| Wet mud | 2512 |
| Wood | 1300 - 2400 |
| Zinc | 388 |
| Zirconium | 280 |
- 1 calorie = 4.186 joules = 0.001 Btu/lbm oF
- 1 cal/gram Co = 4186 J/kgoC
- 1 J/kg Co = 10-3 kJ/kg K = 10-3 J/g Co = 10-6 kJ/g Co= 2.389×10-4 Btu/lbmoF
For conversion of units, use the Specific heat online unit converter.
• Thermodynamics
Dirt and Mud - Densities
Densities - pound per cubic foot and kilograms per cubic metre - of dirt and mud.
Electric Heating of Mass
Electric heating and temperature change vs. energy supplied.
Energy Storage Density
Energy density - by weight and volume - for some ways to store energy
Heat Capacity
Heating Up Applications - Energy Required and Heat Transfer Rates
Energy required to heat up a substance.
Metals - Specific Heats
Mixing Fluids
Final mass and temperature when mixing fluids.
Mixing Liquids and/or Solids - Final Temperatures
Calculate the final temperature when liquids or solids are mixed
Pipes Submerged in Oil or Fat - Heat Emission
Heat emission from steam or water heating pipes submerged in oil or fat - forced and natural circulation.
Polymers - Specific Heats
Specific heat of polymers like epoxy, PET, polycarbonate and more.
Storing Thermal Heat
Energy stored as sensible heat in different types of materials.
Units of Heat - BTU, Calorie and Joule
The most common units of heat BTU - British Thermal Unit, Calorie and Joule.
