Mixing Fluids
The final mass and temperature when mixing fluids are calculated below.
Final Mass of Mixed Fluids
m = m1 + m2 + ... + mn (1)
m = final mass (kg, lb)
m1..n = mass of substances
Final Temperature of Mixed Fluids
t = (m1 c1 t1 + m2 c2 t2 + ... + mn cn tn ) / (m1 c1 + m2 c2 + ... + mn cn ) (2)
t = final temperature ( oC, oF)
c1..n = specific heat of substances (kJ/kg oC, Btu/lb oF)
t1..n = temperatures of substances ( oC, oF)
Example - Mixing Water with Different Temperatures
10 kg of water with temperature 10 oC is mixed with 2 kg water with temperature 100 oC. Specific heat of water is 4.2 kJ/kg oC.
The final mass of the mixture is
m = (10 kg) + (2 kg)
= 12 kg
The final temperature of the mixture is
t = ((10 kg) (4.2 kJ/kg. oC) (10 oC) + (2 kg) (4.2 kJ/kg. oC) (100 oC)) / ( (10 kg) (4.2 kJ/kg. oC) + (2 kg) (4.2 kJ/kg. oC))
= 25 oC
Mixing Fluids - Final Mass and Temperature Calculator
The calculator below can be used to calculate the final mass and temperature when mixing two fluids.
Fluid 1:
specific heat (kJ/kg oC, Btu/lb oF)
Fluid 2:
Mixing Fluids - Required Temperature Calculator
Calculate required temperature for one of the fluids to achieve a final mixed temperature.
Mixture
Fluid 1:
Fluid 2:
Mixing Fluids - Required Mass Calculator
Calculate required mass for one of the fluids to achieve a final mixed temperature.
Mixture
Fluid 1:
Fluid 2:
Domestic Hot Water Service Systems - Design Procedures
Design procedures for domestic hot water service systems.
Metals - Specific Heats
Mixing Liquids and/or Solids - Final Temperatures
Calculate the final temperature when liquids or solids are mixed
Mixtures, Solutions and Suspensions
Mixtures vs. solutions vs. suspensions.
Solids - Specific Heats
Specific Heat of Common Liquids and Fluids
Specific Heat of Common Materials – Engineering Reference
